Private vlan SVI routing
Liad Dayan
Hi guys,
I have a question:
I have a topology that goes :
Host - > SwitchA - > SwitchB(Layer3) - > CORE NETWORK - > ISP
Host want to reach the Core network, but from some reason it cant.
Host can ping SwitchB SVI interface(which configured as default gateway).
but cant go out to the CORE network.
between SwitchB to CORE NETWORK we have igp that routing the subnets, CORE networks can reach SwitchB SVI but cant reach HOST.
further notice, when i open Wireshark on HostA i manage to see that ICMP from CORE NETWORKS got received and sent back.
but CORE NETWORK didn't receive the replay.
Any one has any idea?
now the host port is configured as follows :(at host A)
vlan 1135 - primary
vlan 2135 - secondary (isolated)
interface gigabitethernet x/x
description "Connect to host X"
switchport mode private-vlan host
switchport private-vlan host-association 1135 2135
interface port-channel x
description "Connect to SwitchB"
switchport
switchport mode trunk
SwitchB configuration:
description "Connect to SwitchA"
switchport
interface vlan 1135
ip address x.x.x.x/24
private-vlan mapping 2135
interface vlan 20
"description OSPF TO CORE"
ip address x.x.x.x/30
ip ospf 1 area 0.0.0.0
dukenuk96
Level 3
Level 3
Please make your question more clear - show full network diagram and all configs. From your partial configs it is impossible to determine how devices are interconnected and what address you are trying to ping.
I will try to explain my problem:
I have a L3 switch, that got PRIVATE VLAN on him.
I want this L3 switch to route traffic to and from that PRIVATE VLAN.
Here is the configuration in the L3 switch:
CISCO#show vlan private-vlan
Primary Secondary Type Ports
1135 2135 isolated
CISCO#show interface private-vlan mapp
Interface Secondary VLAN Type
vlan1135 2135 isolated
interface Vlan1135
vrf forwarding SLIMM
ip address 132.76.27.254 255.255.255.128
ip ospf 4 area 1
for L3 the interconnect to the CORE network i have a different interface :
interface Vlan831
mtu 9170
ip address 172.17.204.26 255.255.255.252
ip ospf network point-to-point
ip ospf hello-interval 1
ip ospf 4 area 1
here is the output from the show ip route on that VRF :
CISCO#show ip route vrf SLIMM
O*IA 0.0.0.0/0 [110/2] via 172.17.204.25, 2w3d, Vlan831
132.76.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 132.76.27.128/25 is directly connected, Vlan1135
L 132.76.27.254/32 is directly connected, Vlan1135
172.17.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 172.17.204.24/30 is directly connected, Vlan831
L 172.17.204.26/32 is directly connected, Vlan831
Now, to the problem :
All devices that are in vlan 2135 CAN ping the default gateway, but the CANT ping interfaces in the CORE network.
When i put wireshark on one of the PC`s that connected to the PVLAN iam able to see the ICMP request from the CORE interface, and ICMP Replay to the IP interface, but from some reason it get dropped in the middle.
I have upload a simple Network topology for your undestanding.
Anyone has any idea?
