Private-VLAN using Nexus 7010 and 2248TP FEX
toddriesz
I have a Nexus 7010 with several 2248TP FEX modules.
I am trying to configure a Private VLAN on one of the FEX host ports.
I see in the documentation you can't do promiscous but I can't even get the host only configuration to take.
Software
  BIOS:      version 3.22.0
  kickstart: version 6.0(2)
  system:    version 6.0(2)
sho run | inc private
feature private-vlan
vlan 11
  name PVLAN_Primary
  private-vlan primary
  private-vlan association 12
vlan 12
  name PVLAN_Secondary
  private-vlan isolated
7010(config)# int e101/1/48
7010(config-if)#
7010(config-if)# switchport mode ?
  access        Port mode access
  dot1q-tunnel  Port mode dot1q tunnel
  fex-fabric    Port mode FEX fabric
  trunk         Port mode trunk
Switchport mode private-vlan doesn't even show up!!!!!!
If I try this command it says its not allowed on the FEX port.
7010(config-if)# switchport private-vlan host-association 11 12
ERROR: Requested config not allowed on fex port
What am I doing wrong?????
Todd
Have you found a solution to this?
-Jeremy
