Priviledge mode on router
Andy White
Level 3
Level 3
What priviledge mode can I give our backup server?  I what to give it a priviledge mode where it can only back it up an do nothing else, currently I have it at level 15.
Also is there a read only priviledge?
justinmitchell
Level 4
Level 4
Depending on what you have the server doing, you can create additional privilege levels and assign specific commands the privilege is able to run.
http://www.cisco.com/en/US/partner/docs/ios/security/command/reference/sec_p2.html#wp1034201
You can also use SNMP to backup configuration files.
Florin Barhala
Level 6
Level 6
I would suggest you to use an automatic backup script using KRON if supported by your appliance.
