Probably an easy switch config question.
jdenzer
I have a Cisco 4900M switch. It has two of the 8 port RJ-45 TenGig Ethernet cards in it. Was initially set up by a consultant.
I have used the first 8 ports on the first card. I just went to the 9th server, and now when I plug the ethernet cable into any of the 8 ports on the second card I get no link, nothing. The interface shows down, line protocol down (notconnect). A "show vlan" shows all the ports from BOTH cards are in Vlan1.
I did a "show tech support", and found some differences between the ports that work, and the ones that don't. Here are examples:
On a port that does not work the VlanID shows 4095. The STP state shows vlan 4095 (blocked)
On a port that does work the VlanID shows 1. The STP state shows vlan1 (forwarding).
So I think I found the issue, just don't know how to correct it.
Looking at what you have here, might be a bad module, maybe try re-seating it. If it does not work I presume, get Cisco TAC involved.
8 Replies 8
You need to assign the port you want to use to a particular vlan for it to work.
for example:
conf t
int gi0/9
switchport mode access
switchport access vlan 1
spanning-tree portfast
Hope that helps.
Reza Sharifi
If the port is down and line protocol down (notconnect), then you have a layer-1 issue.  Check your cable and make sure it is good.
Thanks for the replies.
Cable is OK, lights right up when unplugged from the 4900 port and put into a port on a 3750E.
Tried those commands. That did not work either. Nothing appears to have changed with the config, still showing 4095 and blocked.
There are some error messages in the tech-support: linecard-4-ethphyseuevent: te3/3 detected a soft error event--recovery process completed. See multiples of this.
can you post the following:
sh run int xxx {one for the interface that works and one for interface that does not work}
sh int xxx capabilities {one for the interface that works and one for interface that does not work}
sh vlan
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.02.22 12:38:13 =~=~=~=~=~=~=~=~=~=~=~= User Access Verification Password: Cisco-4900-Core>enable Password: Cisco-4900-Core#sho run inrt      terface te3/3 Building configuration... Current configuration : 87 bytes ! interface TenGigabitEthernet3/3 switchport mode access spanning-tree portfast end Cisco-4900-Core#sho run interface te3/3                  interface te3/3                    interface te3/3                    interface te3/3                  interface te3/3                   interface te3/3   capabilities TenGigabitEthernet3/3   Model:                WS-X4908-10G-RJ45-RJ-45   Type:                  10GBaseT   Speed:                10000   Duplex:                full   Auto-MDIX:            yes   Trunk encap. type:    802.1Q   Trunk mode:            on,off,desirable,nonegotiate   Channel:              yes   Broadcast suppression: percentage(0-100), hw   Multicast suppression: percentage(0-100), hw   Flowcontrol:          rx-(off,on,desired),tx-(off,on,desired)   VLAN Membership:      static, dynamic   Fast Start:            yes   CoS rewrite:          yes   ToS rewrite:          yes   Inline power:          no   SPAN:                  source/destination   UDLD:                  yes   Link Debounce:        no   Link Debounce Time:    no   Port Security:        yes   Dot1x:                yes --More--                             Maximum MTU:          9198 bytes (Jumbo Frames)   Multiple Media Types:  no   Diagnostic Monitoring: N/A   Queuing:              rx-(N/A), tx-(1p7q1t) Cisco-4900-Core#sho              sho interface te3/3 capabilities                /3 capabilities                 2/3 capabilities               /3 capabilities TenGigabitEthernet2/3   Model:                WS-X4908-10G-RJ45-RJ-45   Type:                  10GBaseT   Speed:                10000   Duplex:                full   Auto-MDIX:            yes   Trunk encap. type:    802.1Q   Trunk mode:            on,off,desirable,nonegotiate   Channel:              yes   Broadcast suppression: percentage(0-100), hw   Multicast suppression: percentage(0-100), hw   Flowcontrol:          rx-(off,on,desired),tx-(off,on,desired)   VLAN Membership:      static, dynamic   Fast Start:            yes   CoS rewrite:          yes   ToS rewrite:          yes   Inline power:          no   SPAN:                  source/destination   UDLD:                  yes   Link Debounce:        no   Link Debounce Time:    no   Port Security:        yes   Dot1x:                yes --More--                             Maximum MTU:          9198 bytes (Jumbo Frames)   Multiple Media Types:  no   Diagnostic Monitoring: N/A   Queuing:              rx-(N/A), tx-(1p7q1t) Cisco-4900-Core#sho run interface te2/3 Building configuration... Current configuration : 87 bytes ! interface TenGigabitEthernet2/3 switchport mode access spanning-tree portfast end Cisco-4900-Core#sho vlan VLAN Name                            Status    Ports ---- -------------------------------- --------- ------------------------------- 1    default                          active    Te1/1, Te1/2, Te1/3, Te1/7                                                 Te2/1, Te2/2, Te2/3, Te2/4                                                 Te2/5, Te2/6, Te2/7, Te2/8                                                 Gi2/9, Gi2/10, Gi2/11, Gi2/12                                                 Gi2/13, Gi2/14, Gi2/15, Gi2/16                                                 Te3/1, Te3/2, Te3/3, Te3/4                                                 Te3/5, Te3/6, Te3/7, Te3/8                                                 Gi3/9, Gi3/10, Gi3/11, Gi3/12                                                 Gi3/13, Gi3/14, Gi3/15, Gi3/16 10  Voice-Servers                    active    110  Data                            active    111  Voice                            active    112  Wireless-User                    active    113  Wireless-mgmt                    active    1002 fddi-default                    act/unsup 1003 token-ring-default              act/unsup 1004 fddinet-default                  act/unsup 1005 trnet-default                    act/unsup VLAN Type  SAID      MTU  Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2 --More--                           ---- ----- ---------- ----- ------ ------ -------- ---- -------- ------ ------ 1    enet  100001    1500  -      -      -        -    -        0      0  10  enet  100010    1500  -      -      -        -    -        0      0  110  enet  100110    1500  -      -      -        -    -        0      0  111  enet  100111    1500  -      -      -        -    -        0      0  112  enet  100112    1500  -      -      -        -    -        0      0  113  enet  100113    1500  -      -      -        -    -        0      0  1002 fddi  101002    1500  -      -      -        -    -        0      0  1003 tr    101003    1500  -      -      -        -    -        0      0  1004 fdnet 101004    1500  -      -      -        ieee -        0      0  1005 trnet 101005    1500  -      -      -        ibm  -        0      0  Remote SPAN VLANs ------------------------------------------------------------------------------ Primary Secondary Type              Ports ------- --------- ----------------- ------------------------------------------ Cisco-4900-Core# Port te2/3 works, te3/3 does not.
Boy is that ugly. Cut and paste don't work so well.
Cisco tech support agrees. They are sending a new card. Thanks!
