Probe fail for rserver
vishh_champ
If probe fails for a rserver what will ACE do with the current connections
Giuseppe Larosa
Hello Vishal,
the ACE should put the rserver in out of service during the time the probes fail.
As a result of this current TCP sessions should be terminated.
you can configure the type of probes, their frequencies and how many failures to wait before a reaction occurs.
see
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A2/configuration/slb/guide/probe.html#wp1030738
Hope to help
Giuseppe
