Problem 3560v2 series poe 24
ahmad.azak
Dear all
     I am facing a problem with a 3560v2
the sys and rps leds gives amber allert , also when booting the swith in normal mode it shows attached and then hangs.
also find attached dir flash from the room mode.
Kindly advise and help.
Ahmad Zin
Ain Shams
Network Engineer
Leo Laohoo
You are running 15.0(1)SE1????
Try a different IOS.  The version you are running is very, very buggy.
Try either 15.0(2)SE4 or 12.2(55)SE8.
