Problem About IP MTU
rogetnoprl
hello, I am confused with mtu settings,here are problems:
a windows server is in vlan 21,and the interface ethernet to the server is 1500
however, when i change int vlan 21 ip mtu to 1280,and I run "ping IP -f -l 1472" can still get reply from the other host.the other host is in another VLAN routed by this switch(cisco 4506),
it seems there is nothing happend when I change the IP mtu of this VLAN interface, so I want to know what happened to the IP packet which was translated  when the switch has vlan interface IP MTU 1280? Did it fragmented? I believe that "ping -f" set the DF bit, it should not to be fragmented
flokki123
Level 3
Level 3
hi roget,
i guess the receiving interface on the switch is still set to mtu 1500, right?
what if you set this to 1280 as well? does the ping still work?
and yes, -f with the ping command tells the device to not fragment the packet.
florian
Yes.The receiving interface MTU is 1500. and I Can't set interface MTU to 1280,
sw-a5-01-C4506-E(config-if)#mtu 9198
% Interface GigabitEthernet4/38 does not support user settable mtu.
sw-a5-01-C4506-E(config-if)#mtu 1280
% Invalid input detected at '^' marker
there is someting i found,
if I set vlan IP mtu to 1280 ,and the vlan has an IP, and i Ping VLANIP -f -l 1500 got "request time out" reply.ping VLANIP -f -l 1208 got reply
so what happend to the packet(to other server) if the vlan ip mtu is 1280? VLAN ip is default gateway of this VLAN
