Cisco 6500 help needed
The_guroo_2
Level 2
Level 2
Guys we have an old 6500 running IOS and CAToS.....i wanted to see what modules this 6500 has and tried to run all commands like sh inventory, sh moudle but non of them work
sh module ?
  ContentSwitchingModule  CSM SLB module information
i tried both but its doesnt seems to give information i want
all i want is the info whoich normally is get by sh module
can someone help me plz
the show ver is as under
IOS (tm) MSFC2 Software (C6MSFC2-JSV-M), Version 12.1(27b)E4, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Fri 29-Feb-08 15:04 by hqluong
Image text-base: 0x40008EF4, data-base: 0x41B76010
ROM: System Bootstrap, Version 12.1(11r)E1, RELEASE SOFTWARE (fc1)
BOOTLDR: MSFC2 Software (C6MSFC2-BOOT-M), Version 12.1(26)E1, RELEASE SOFTWARE (fc2)
System restarted at 11:41:13 AEST Thu Feb 24 2011
System image file is "bootflash:c6msfc2-jsv-mz.121-27b.E4.bin"
cisco MSFC2 (R7000) processor with 114688K/16384K bytes of memory.
R7000 CPU at 300Mhz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
21 Virtual Ethernet/IEEE 802.3  interface(s)
509K bytes of non-volatile configuration memory.
32768K bytes of Flash internal SIMM (Sector size 512K).
nkarpysh
In Hybrid mode you can can see "show module" on SP processor (CATOS). So you can exit from MSFC (RP) mode and will get to SP where you can run it. "show ver" under SP also showing similar deteails. Hope it helps.
Nik
HTH,
Niko
