problem accessing a 3550 switch
sie.xarxa.edu
Visitor
When accessing by the console port, by rollover cable, I just cannot send any character, but i get all the feed back from the switch.
Any idea?
Here is the config of the con:
________________________________________
switch#sh line con 0
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
0 CTY - - - - - 0 0 0/0 -
Line 0, Location: "", Type: "vt100"
Length: 24 lines, Width: 128 columns
Baud rate (TX/RX) is 9600/9600, no parity, 1 stopbits, 8 databits
Status: Ready, 0x40000
Capabilities: none
Modem state: Ready
Special Chars: Escape Hold Stop Start Disconnect Activation
^^x none - - none
Timeouts: Idle EXEC Idle Session Modem Answer Session Dispatch
00:10:00 never none not set
Idle Session Disconnect Warning
never
Login-sequence User Response
00:00:30
Autoselect Initial Wait
not set
Modem type is unknown.
Session limit is not set.
Time since activation: never
Editing is enabled.
History is enabled, history size is 20.
DNS resolution in show commands is enabled
Full user help is disabled
Allowed input transports are none.
Allowed output transports are telnet ssh.
Preferred transport is telnet.
No output characters are padded
No special data dispatching characters
_________________________________________
I only observed that there is never the enable status or the active one. Only the ready one.
aghaznavi
Level 10
Level 10
Connect the rollover cable to the port marked CONSOLE on the rear panel of the switch.
If needed, connect the appropriate Terminal DTE adapter to the COMM port on the back of the PC.
Connect the other end of the rollover cable to the PC that runs the Terminal Emulation Software.
Start the Terminal Emulation software.For example, complete these steps in order o start Hyper Terminal Emulation Software on the PC:
From the Start Menu, choose Programs > Accessories > Hyper Terminal.
This opens the Hyper Terminal folder in a new window.
Double-click on Hypertrm.exe file.
This starts the Hyper Terminal Software and a new window appears.
Enter the Name of the Connection, under Name, and click OK.
You see a popup window that shows Country code, Area code, Phone number, and Connect using.
From the pull-down button in front of Connect Using, choose Direct to Com 1 or Direct to Com 2, which depends on the COM port on which you have connected the DTE Terminal Adapter, and click OK.
You see another popup window labeled as COM1 Properties.
Make these selections from the pull-down buttons:
Bits per second: 9600
Data Bits: 8
Parity: None
Stop bits: 1
Flow control: None
After you make the selections, click OK.
You see a blank, white screen with cursor that blinks on the top-left corner.
Once connected, if you want to save this session for your future use, from the File menu, choose Save.
This session is saved in the Hyper Terminal folder in a file that is named file_name.ht, where file_name is the name of the connection that you have previously saved.
Note: In the future, if you want to connect with the use of the saved file, simply double-click the file_name.ht file in the Hyper Terminal folder.
http://www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note09186a00800946e5.shtml#consoleaccess
Thank's for the information provided.
Actually the problem was located at physical level. We simply needed to open the switch and verifying the 8 pins of the female RJ45 connector, one of them were tortured, and everything went OK.
Thanks again.
greetings
