Problem adding switch to switchstack "Incompatible Software"
baskervi
Level 5
Level 5
We've had a couple switches lying around, and now we need the additonal switch ports. However, we're having problem adding them to the swtich stack, and I've included the information. Switch 7 has the same feature set, but a newer version of firmware. The older versions are deferred. I thought about tftping the firmware from the existing stack to our server, and then placing this on the other switches, but maybe there is a better way. I'd appreciate some input on this. Thanks
Switch   Ports  Model              SW Version              SW Image
     1   28     WS-C3750G-24TS     12.2(25)SEC1            C3750-ADVIPSERVICESK
     2   28     WS-C3750G-24TS     12.2(25)SEC1            C3750-ADVIPSERVICESK
     3   28     WS-C3750G-24TS     12.2(25)SEC1            C3750-ADVIPSERVICESK
     4   28     WS-C3750G-24TS     12.2(25)SEC1            C3750-ADVIPSERVICESK
*    5   28     WS-C3750G-24TS     12.2(25)SEC1            C3750-ADVIPSERVICESK
     6   28     WS-C3750G-24TS     12.2(25)SEC2            C3750-IPBASE-M
     7   0      WS-C3750G-24TS     12.2(35)SE5             C3750-ADVIPSERVICESK
413086: Dec  6 21:15:37: %IMAGEMGR-6-AUTO_COPY_SW_INITIATED: Auto-copy-software process initiated for switch number(s) 7
413087: Dec  6 21:15:37: %IMAGEMGR-6-AUTO_COPY_SW:
413088: Dec  6 21:15:37: %IMAGEMGR-6-AUTO_COPY_SW: Searching for stack member to act
413089: Dec  6 21:15:37: %IMAGEMGR-6-AUTO_COPY_SW: as software donor...
413090: Dec  6 21:15:37: %IMAGEMGR-6-AUTO_COPY_SW: Software was not copied
413091: Dec  6 21:15:37: %IMAGEMGR-6-AUTO_ADVISE_SW_INITIATED: Auto-advise-software process initiated for switch number(s) 7
413092: Dec  6 21:15:38: %IMAGEMGR-6-AUTO_ADVISE_SW:
413093: Dec  6 21:15:38: %IMAGEMGR-6-AUTO_ADVISE_SW:
413094: Dec  6 21:15:38: %IMAGEMGR-6-AUTO_ADVISE_SW: Systems with incompatible software have
413095: Dec  6 21:15:38: %IMAGEMGR-6-AUTO_ADVISE_SW: been added to the stack.  The storage
413096: Dec  6 21:15:38: %IMAGEMGR-6-AUTO_ADVISE_SW: devices on all of the stack members have
413097: Dec  6 21:15:38: %IMAGEMGR-6-AUTO_ADVISE_SW: been scanned, and the software required
413098: Dec  6 21:15:38: %IMAGEMGR-6-AUTO_ADVISE_SW: to make all stack members compatible with
413099: Dec  6 21:15:38: %IMAGEMGR-6-AUTO_ADVISE_SW: each other was not found. The "archive
413100: Dec  6 21:15:38: %IMAGEMGR-6-AUTO_ADVISE_SW: download-sw" command can be used to
413101: Dec  6 21:15:38: %IMAGEMGR-6-AUTO_ADVISE_SW: install software off of the network from
413102: Dec  6 21:15:38: %IMAGEMGR-6-AUTO_ADVISE_SW: a tar file.
413103: Dec  6 21:15:38: %IMAGEMGR-6-AUTO_ADVISE_SW:
jakob.a.stevens92
Community Member
Hello
Best of luck to you,
- Jakob
