Showing results forĀ
Search instead forĀ
Did you mean:Ā
Problem between managed switch and unmanaged switch
athraya
Visitor
Hello all,
I have problem of communication between unmanaged switch and managed switch :
Router --> GE1 , Mode Trunk  (Vlan 10& 20)---CISCO SF300--- FE10 , switch port mode acess (Vlan10) --> unamaged Switch --> PC
The PC not ping the Router...
Router --> GE1 , Mode Trunk  (Vlan 10& 20)---CISCO SF300--- FE10 , switch port mode acess (Vlan10) --> PC
The PC ping the Router...
Thank you for your help.
devils_advocate
Level 11
Level 11
What make and model in the unmanaged switch?
Are you sure its Vlan capable?
Does Vlan10 exist on the unmanaged switch?
