[Problem] Cisco 3560 Switch: Unable to ping to different VLAN
Hi all,
Here is my topology. I’ve created to VLAN and I can ping each host in the same VLAN. Unfortunately, I can’t ping a host on different VLAN.
Ping Test
SERVER>ipconfig
FastEthernet0 Connection:(default port)
Link-local IPv6 Address.........: FE80::260:3EFF:FE09:EBE8
IP Address......................: 4.1.1.1
Subnet Mask.....................: 255.0.0.0
Default Gateway.................: 0.0.0.0
SERVER>ping 4.1.1.2
Pinging 4.1.1.2 with 32 bytes of data:
Reply from 4.1.1.2: bytes=32 time=0ms TTL=128
Ping statistics for 4.1.1.2:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
SERVER>ping 3.1.1.1
Pinging 3.1.1.1 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 3.1.1.1:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
SERVER>
All interfaces are connected and up
S1#sh ip int b
FastEthernet0/1 unassigned YES unset up up
FastEthernet0/2 unassigned YES unset up up
FastEthernet0/3 unassigned YES unset up up
FastEthernet0/4 unassigned YES unset up up
Vlan1 unassigned YES unset administratively down down
Vlan30 3.1.1.10 YES manual up up
Vlan40 4.1.1.10 YES manual up up
S1#
S2#sh ip int b
Vlan30 3.1.1.20 YES manual up up
Vlan40 4.1.1.20 YES manual up up
S2#
Routing looks good
S1#sh ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is not set
3.0.0.0/24 is subnetted, 1 subnets
C 3.1.1.0 is directly connected, Vlan30
4.0.0.0/24 is subnetted, 1 subnets
C 4.1.1.0 is directly connected, Vlan40
S1#
S2#sh ip route
S2#
Trunk Status
S1#sh int trunk
Port Mode Encapsulation Status Native vlan
Fa0/1 on 802.1q trunking 1
Port Vlans allowed on trunk
Fa0/1 1-1005
Port Vlans allowed and active in management domain
Fa0/1 1,30,40
Port Vlans in spanning tree forwarding state and not pruned
Fa0/1 1,30,40
S1#
S2#sh in tr
Fa0/1 auto n-802.1q trunking 1
Fa0/1 1-1005
Fa0/1 1,30,40
Fa0/1 1,30,40
S2#
Here is my switches config. Please let me know how to troubleshoot/solve this issue. Thanks.
S1#sh run
Building configuration...
Current configuration : 1405 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname S1
enable password ep
ip routing
spanning-tree mode pvst
interface FastEthernet0/1
switchport mode trunk
interface FastEthernet0/2
interface FastEthernet0/3
switchport access vlan 30
interface FastEthernet0/4
switchport access vlan 40
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan30
ip address 3.1.1.10 255.255.255.0
interface Vlan40
ip address 4.1.1.10 255.255.255.0
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
exec-timeout 0 0
password lv
login
end
S1#
S2#sh run
Current configuration : 1326 bytes
version 12.2
hostname S2
enable password ep
ip routing
interface Vlan1
no ip address
shutdown
interface Vlan30
ip address 3.1.1.20 255.255.255.0
interface Vlan40
ip address 4.1.1.20 255.255.255.0
ip classless
line con 0
line aux 0
line vty 0 4
password lv
login
end
S2#
https://firewallengineer.wordpress.com/2014/12/27/problem-cisco-3560-switch-unable-to-ping-to-different-vlan/
You can ping the other network, rather you can not ping the host.
Given you had the servers config wrong, the chances are the clients are as well.
Therefore, check the clients S/M and G/W are correct.
Martin
9 Replies 9
Leo Laohoo
Sounds like firewall on 3.1.1.1 is enabled.
Thanks Leo for your prompt response. Firewall is disabled. I can ping 3.1.1.1 from 3.1.1.2 (different switch, same VLAN)
But I can’t ping from the same switch, different VLAN
PC>ipconfig
Link-local IPv6 Address.........: FE80::2D0:BAFF:FE54:C865
IP Address......................: 3.1.1.2
PC>ping 3.1.1.1
Reply from 3.1.1.1: bytes=32 time=10ms TTL=128
Reply from 3.1.1.1: bytes=32 time=0ms TTL=128
Reply from 3.1.1.1: bytes=32 time=1ms TTL=128
Minimum = 0ms, Maximum = 10ms, Average = 2ms
PC>tracert 3.1.1.1
Tracing route to 3.1.1.1 over a maximum of 30 hops:
1 0 ms 0 ms 0 ms 3.1.1.1
Trace complete.
PC>
This is what's wrong:
It needs to be:
Subnet Mask.....................: 255.255.255.0
Default Gateway.................: 3.1.1.10
The mask needs to be correct so that the host knows when the host is on a different subnet, and the default gateway needs to be configured to that the host knows where to send packets that should be transported to a different subnet.
Thanks Henrik,
I’ve fixed the gateway & subnet but still can’t ping to different VLAN.
BEFORE
SERVER>ipconfig
SERVER>ping 3.1.1.1
Request timed out.
Request timed out.
Request timed out.
Request timed out.
AFTER
SERVER>ipconfig
   Default Gateway.................: 4.1.1.10
SERVER>ping 4.1.1.10
Pinging 4.1.1.10 with 32 bytes of data:
Reply from 4.1.1.10: bytes=32 time=0ms TTL=255
Ping statistics for 4.1.1.10:
SERVER>
SERVER>ping 3.1.1.1
Request timed out.
Request timed out.
Request timed out.
Request timed out.
SERVER>
What happends when you ping 3.1.1.10?
I can ping it. (from 4.1.1.1)
SERVER>ping 3.1.1.10
Pinging 3.1.1.10 with 32 bytes of data:
Reply from 3.1.1.10: bytes=32 time=0ms TTL=255
Ping statistics for 3.1.1.10:
SERVER>
Martin
Aaah, you're right Martin. I did the same mistake on the other host. Gateway was not configured.
Now I'm able to ping to all hosts even in different VLAN.
Thanks all, I really appreciate your help.
You have not mentioned gateway/default-router address. Thats why you are not able to ping different vlans.
