Problem configuring TCP intercept
manuel.dennis
Level 2
Level 2
I am having a problem configuring TCP intercept.
I follow the example in the configuring TCP Intercept PDF (attached) I downloaded from Cisco.
In the terminal configuration mode, I enter:
access-list 101 permit tcp any 192.168.1.0 0.0.0.255
(using my actual IP address range of course)
and
ip tcp intercept list 101
I get an invalid entry response from the IOS with the ^ under the i in intercept.
I am not running NAT.
Any ideas?
Antonio Knox
Level 11
Level 11
Check the IOS version in Cisco Feature Navigator.  It may not be supported.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Antonio Knox
Level 11
Level 11
I am running c3845-advsecurityk9-mz.151-3.T.   It is not listed as supporting TCP Intercept.  So now I know why I can't configure it.  Strange that other versions of 15.1(3) do but this one doesn't.  It never occured to me that some version of a base IOS wouldn't support all the features supported by the base IOS.  Thanks.
Manny
Happens to us all my friend.
