problem enable ssh switch C4500X16FP
eddanilo2016
Frequent Visitor
Frequent Visitor
Hi Guys
I need help on switch since it does not allow to configure ssh
this is the information
Versión de software C4500X16FP
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch  Software (cat4500e-UNIVERSAL-M), Version 03.09.00.E RELEASE SOFTWARE (fc1)
ROM: 15.0(1r)SG12
regards
5 Replies 5
Hulk8647
Level 5
Level 5
did you configure your hostname, domain-name and generated crypto key for SSH and then enaled SSH?
What response do you get it you do
crypto ?
Does the file name for the image include "k9"? K9 indicates that the image does have support for crypto and this is a requirement for SSH. Perhaps you could post the output of show version which would allow us to see the file name.
Rick
Rick
Your software (cat4500e-UNIVERSAL-M) does not allow you to configure SSH, for the same reason Rick described.
HTH,
Meheretab
HTH,
Meheretab
Rick is correct (as always). The IOS file does not support crypto. Download the crypto-enabled file, look for a filename with "k9", and load it into the appliance.
