problem getting iOS 15.0.2 to run on 3750-x 48ps-s
DAVID THORNTON
Hello
Trying to get the 10Gbps service module to be recognised requires V15 according to cisco docs
Upgrading from V12.2 55 (or .58) fails on some switches I have tried
Process fails and I finish up at the switch: prompt
I can recover....
The switch can be regressed back to v12.2.55 or .58
But I can't get all of them up to v15
I have tried 5 to date
Same methods producing different results
2 worked
3 failed
Can anyone help throw any light on this
Anyone had similar problems please?
17 Replies 17
Leo Laohoo
What error messages do you get when you attempt to upgrade to 15.0?
Hi and thanks for the reply
I see the following ...
switch: set IP_ADDR 172.19.100.80/255.255.0.0
switch: set DEFAULT_ROUTER 172.19.1.128
switch: copy tftp://172.19.6.56/c3750e-universalk9-mz.150-2.SE.bin flash:/c3750e-universalk9-mz.150-2.SE.bin
Then…
File "tftp://172.19.6.56/c3750e-universalk9-mz.150-2.SE.bin" successfully copied to "flash:/c3750e-universalk9-mz.150-2.SE.bin"
switch: boot flash:/c3750e-universalk9-mz.150-2.SE.bin
Loading "flash:/c3750e-universalk9-mz.150-2.SE.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
Then..
File "flash:/c3750e-universalk9-mz.150-2.SE.bin" uncompressed and installed, entry point: 0x3000
executing...
Boot process failed...
switch:
Thank you for any help
Ok, the file you've copied is probably corrupt.
You can transfer the IOS (faster) from your client to the 3750X using a USB.  You can also boot the 3750X from the USB.
Make sure your USB stick is format with FAT16.
Now, back to your problem of a corrupt IOS.  Go to the Cisco website and compare the MD5 hash with the website.
Thanks for the tips
But ....
Same file works on Two of the five devices ......
Used same FTP
I don't see how it could be corrupted ?
Will check hashes
Hashes fine
Tried USB
Tried tFTP
Copy from USB to flash
On 5 switches , two upgraded three wont. .... They will recover back to v12 ok
No pattern I can see
It seems random
But there must be some difference in the kit ????
Ok, let say that you have a valid BIN file in the USB.
Stick the USB into the 3750X that ain't booting.  Try the following lines:
1.  flash_init
2.  boot usbflash0:c3750e-universalk9-mz.150-2.SE.bin
ollieandrews
Did you ever get to the bottom of this? We're seeing the same issue on 48port 3750-X's.
Some take 15.0(2) some don't, some fail to ROMMON with that version in place, some just hang.
15.0(1) works fine.
Jonathan Hall
I'm getting the same issue.
I've got one WS-C3750X-24T-E on which 15.0(2)SE4 is working fine and two WS-C3750X-24T-S which fail to rommon with the boot proccess failed message.
I'm also getting the same issue yetserday.
I was trying to up upgrade a stack (3 x 3750X-24T). On one switch, added one day before to the stack was upgraded, has no problem with 15.0(2) and the other two switches are hanging within the bootprocess after loading IOS.
Has anyone a solution?
What error are you getting before it throws you in rommon?
If you can tell the exact error we might be able to get you a solution.
Ankur
IOS-upgrade with switch#archive tar /xtract tftp://192.168.1.10/c3750e-universalk9-tar.150-2.SE5.tar flash:  was working fine, without problems. After reboot the switch is starting up to:
switch: boot flash:/c3750e-universalk9-mz.150-2.SE5/c3750e-universalk9-mz.150-2.SE5.bin
Loading "c3750e-universalk9-mz.150-2.SE5/c3750e-universalk9-mz.150-2.SE5.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@  (much more @ were to see)
The number of @@@@ and the time of loading IOS let me suppose all IOS was loading, but there was no more output to see. The system LED gone out and nothing more I could do, except to pull out the power cable.
The process was reproducible, also with 150-2.SE2 - for testing I have done.
But because there is a productiv environment (should be available 24 hours/day), I can't do any more tests on this hardware.
Werner,
You are facing this issue because of a bug CSCuj88266
https://tools.cisco.com/bugsearch/bug/CSCuj88266
You might want to open a tac case and get the switch replaced.
Ankur
"Please rate the post, if found useful"
Ankur,
unfortunately I can't open the information to this bug:
Insufficient Permissions to View Bug
This bug contains proprietary information and is not yet publicly available.
Werner
Werner,
I think you don't have access to this bug.
I opened the bug URL and compared the scenario and it exactly matches your symptoms.
So either keep on running this switch with the code its working on or get it replaced.
But the only resolution to this issue would be a replacement of this switch, that is forsure.
Ankur
"Please click on Answered, if your queries are resolved"
