Problem image in Cisco access point 2600
waleedabdalla
IOS Bootloader - Starting system.
flash is writable
FLASH CHIP:  Numonyx Mirrorbit (0089)
Xmodem file system is available.
flashfs[0]: 37 files, 9 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31997952
flashfs[0]: Bytes used: 8958976
flashfs[0]: Bytes available: 23038976
flashfs[0]: flashfs fsck took 15 seconds.
Reading cookie from SEEPROM
Base Ethernet MAC address: 7c:ad:74:db:4d:59
Ethernet speed is 1000 Mb - FULL Duplex
Loading "flash:/ap3g2-k9w8-mx.152-2.JB/ap3g2-k9w8-xx.152-2.JB"...flash:/ap3g2-k9
w8-mx.152-2.JB/ap3g2-k9w8-xx.152-2.JB: no such file or directory
Error loading "flash:/ap3g2-k9w8-mx.152-2.JB/ap3g2-k9w8-xx.152-2.JB"
Interrupt within 5 seconds to abort boot process.
Boot process failed...
The system is unable to boot automatically.  The BOOT
environment variable needs to be set to a bootable
image.
image.
C2600 Boot Loader (AP3G2-BOOT-M) LoaderVersion 12.4(25e)JA1, RELEASE SOFTWARE (f
c1)
Compiled Wed 30-May-12 03:34 by binugopa
ap:
ap:
ap:
how to reset to factory settings ?
2 Accepted Solutions
Wilson Bonilla
Level 3
Level 3
Hello
Here's the procedure you need:
Resetting the Device to Default Settings
If you need to start over during the initial setup process, you can reset the access point to factory default settings.
Resetting to Default Settings Using the MODE Button
Follow these steps to reset the access point to factory default settings using the access point MODE button:
Step 1 Disconnect power (the power jack for external power or the Ethernet cable for in-line power) from the access point.
Step 2 Press and hold the MODE button while you reconnect power to the access point.
Step 3 Hold the MODE button until the Status LED turns amber (approximately 1 to 2 seconds), and release the button. All access point settings return to factory defaults.
http://www.cisco.com/en/US/docs/wireless/access_point/12.4.25d.JA/Configuration/guide/scg12.4.25d.JA-chap4-first.html#wp1034993
Regards.
Wilson B.
Rasika Nayanajith
this post should help you as it describe what you have to do
https://supportforums.cisco.com/thread/2045805
Rasika
Wilson Bonilla
Level 3
Level 3
Hello
Regards.
Wilson B.
Rasika Nayanajith
Rasika
m.rana.ku
Three easy steps to Reset Cisco AP using MODE button:
https://www.youtube.com/channel/UCmZZ2BNGXQH1HPS3uIVnr7A?sub_confirmation=1
https://youtu.be/eGCnTWBEpp8
Step 1: Disconnect power (the power jack for external power or the Ethernet cable for in-line power) from the access point.
Step 2: Press and hold the MODE button while you reconnect power to the access point.
Step 3: Hold the MODE button until the Status LED turns amber (approximately 10 to 12 seconds), and release the Button. All access point settings return to factory defaults.
Cisco_AP #Reset #IT_Support_People IT Support People Facebook Page: https://www.facebook.com/IT_Support-PeopleDesktop-Support-111268543923018 Link for Other Related Videos: Configure Cisco Access Point Standalone/Autonomous using GUI with WPAv2 Authentication Key: ...
