C9200L Serial OID
kmartens1
With the C3750 or X2960 models, we had specific software that is creating asset lists based on SNMP oid scanning. (You can readout the Serial number and model number with the OID's in below.) However with the new C9200L we only find the serial number and model number of the stacking cable - if connected. Is this a softwarebug, or working as intended?
1.3.6.1.2.1.47.1.1.1.1.11.x001: Serial Number
1.3.6.1.2.1.47.1.1.1.1.13.x001: Model number
x= number in the stack
Kind regards,
Kristof
5 Replies 5
balaji.bandi
1.3.6.1.4.1.9.5.1.2.19.  - this is the OID use to get information most of the Csico Switches - what is the outcome of this ?
you can use MIB browser :
https://snmp.cloudapps.cisco.com/Support/SNMP/do/BrowseOID.do?local=en
Note :  Cat 9200L (personally do not believe they have different it should work- if not please suggest)
BB
cmarva
Level 4
Level 4
try x000 instead of x001
.1.3.6.1.2.1.47.1.1.1.1.13.1000 = STRING: "C9200L-48P-4G-E"
.1.3.6.1.2.1.47.1.1.1.1.13.2000 = STRING: "C9200L-48P-4G-E"
.1.3.6.1.2.1.47.1.1.1.1.13.3000 = STRING: "C9200L-48P-4G-E"
.1.3.6.1.2.1.47.1.1.1.1.13.4000 = STRING: "C9200L-48P-4G-E"
kmartens1
Reading out the product number seems to work, but the OID is different then the one on other switches. But I'm still unable to readout the correct serial number. Do you know what the new OID for that is?
Why is it it a different oid for the new C9200L switches? Is this per design?
Can you post output of snmpwalk.
BB
it does change by platform. the 9200s are different than the 2960s, which were different than their predecessor. I have no idea why, it's just the way it is.
the serial corresponds to the same oid instance, so from my previous post, if I grep on 000 while walking the entity.11 oid, I get:
.1.3.6.1.2.1.47.1.1.1.1.11.1000 = STRING: "JAE23270WWE"
.1.3.6.1.2.1.47.1.1.1.1.11.2000 = STRING: "JAE23270WQY"
.1.3.6.1.2.1.47.1.1.1.1.11.3000 = STRING: "JAE23270VQQ"
.1.3.6.1.2.1.47.1.1.1.1.11.4000 = STRING: "JAE23270X1Y"
