Problem in Cisco 881
viniciochango
I need help. I have a problem with Cisco 881, the message is:
*Aug 29 15:38:24.641: %L2TP-3-ILLEGAL: _____:________: ERROR: failed to get cc: no l2tp db hdl,  -Traceback= 0x81CDA7F4z 0x81CDAAE8z 0x81CD8494z 0x81D00900z 0x801B1F90z 0x802911E0z 0x80430CF8z 0x80285CA8z 0x80285CA8z 0x80430DB8z 0x80432A84z 0x80432C14z 0x80432D28z 0x8043CA24z
How can I solve this problem. Is there any IOS in order to solve this. The Actual IOS is:
flash:c880data-universalk9-mz.124-24.T.bin
John Blakley
You can try to flash the ios, but traceback errors can also be indicative of a memory problem. If you have a Cisco login, you can put this error in the interpreter tool and see what it spits back:
https://www.cisco.com/cgi-bin/Support/OutputInterpreter/home.pl
HTH,
John
HTH, John *** Please rate all useful posts ***
