Problem in CISCO1841 %C3600-3-SLOTS: Number of slots in chassis is undefined
husseinmuneer
Dear All,
I have a prolem in a router 1841 so I cahnged the flash and the RAM but the problem still appear, every time go to rommon!!
I changed the registry to default ( 0x2102 ) and problem still appear !!
I went to cookie and make sure from the HEX number for the PCB and change it to ASCII the result is right, the same what appear on the board.
WHat do you think the problem !!!??
Below is the output:
%C3600-3-SLOTS: Number of slots in chassis is undefined.
%SMC-2-BAD_ID_HW: Failed Identification Test in 0/-1/-1 [7/0]
       The module in 0/-1/-1 in this router may not be a genuine
       Cisco product.  Cisco warranties and support programs only
       apply to genuine Cisco products.  If Cisco determines that
       your insertion of non-Cisco memory, WIC cards, AIM cards,
       Network Modules, SPA cards, GBICs or other modules into a
       Cisco product is the cause of a support issue, Cisco may
       deny support under your warranty or under a Cisco support
       program such as SmartNet.
System Bootstrap, Version 12.4(13r)T5, RELEASE SOFTWARE (fc1)
Copyright (c) 2007 by cisco Systems, Inc.
PLD version 0x10
GIO ASIC version 0x127
c1841 platform with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
Upgrade ROMMON initialized
rommon 1 >
Regards.
0 Replies 0
