Problem in switch catalyst 2960
Abubaker Eldrugy
Community Member
I have problem with Switch cat 2960
it no leds appear
and the fan work
and cannot access console.
Plz help
barnesp
Level 2
Level 2
Asssuming your power source is good - it looks like you a broken switch - most likely it's PSU.
Ganesh Hariharan
it no leds appear
and the fan work
and cannot access console.Plz help
Hello Abubaker,
If you are not seeing any LED agfter reboot and cant able to access console. Also assuming if the switch is under cisco contract then raise a cisco TAC for RMA of switch.
Hope it Helps..
-GI
Rate if it Helps
