02-20-2013 01:40 AM - edited 03-07-2019 11:49 AM
Hi all,
on a WS-C4507R-E there is this configurations:
Cat4507#sh ver
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASEK9-M), Version 12.2(54)SG1, RELEASE SOFTWARE (fc1)
Image text-base: 0x10000000, data-base: 0x12C41C68
ROM: 12.2(44r)SG5
Darkside Revision 4, Nexu Revision 9, Fortooine Revision 1.22
System image file is "bootflash:cat4500e-ipbasek9-mz.122-54.SG1.bin"
Cat4507#sh redundancy
Redundant System Information :
Available system uptime = 28 weeks, 4 days, 17 hours, 5 minutes
Switchovers system experienced = 3
Standby failures = 76
Last switchover reason = user forced
Hardware Mode = Duplex
Configured Redundancy Mode = Stateful Switchover
Operating Redundancy Mode = Stateful Switchover
Maintenance Mode = Disabled
Communications = Up
Current Processor Information :
Active Location = slot 4
Current Software state = ACTIVE
Uptime in current state = 26 weeks, 19 hours, 56 minutes
Image Version = Cisco IOS Software, Catalyst 4500 L3 Switch Sof
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 27-Jan-11 12:19 by prod_rel_team
BOOT = bootflash:cat4500e-ipbasek9-mz.122-54.SG1.bin,1
Configuration register = 0x2102
Peer Processor Information :
Standby Location = slot 3
Current Software state = STANDBY HOT
Uptime in current state = 1 day, 15 hours, 41 minutes
Cat4507#sh module 3
Mod Ports Card Type Model Serial No.
3 6 Sup 6L-E 10GE (X2), 1000BaseX (SFP) WS-X45-SUP6L-E
M MAC addresses Hw Fw Sw Status
3 68ef.bd3e.66c0 to 68ef.bd3e.66c5 1.1 12.2(44r)SG5 12.2(54)SG1 Ok
Mod Redundancy role Operating mode Redundancy status
3 Standby Supervisor SSO Standby hot
Cat4507#sh module 4
4 6 Sup 6L-E 10GE (X2), 1000BaseX (SFP) WS-X45-SUP6L-E
4 68ef.bd3e.66c6 to 68ef.bd3e.66cb 1.0 12.2(44r)SG5 12.2(54)SG1 Ok
4 Active Supervisor SSO Active
This is a problem :
Feb 16 00:09:33.137 MET: %C4K_REDUNDANCY-4-KEEPALIVE_WARNING: Keepalive messages from peer Supervisor are missing for 27 seconds
Feb 16 00:09:42.982 MET: %C4K_REDUNDANCY-3-COMMUNICATION: Communication with the peer Supervisor has been lost
Feb 16 00:09:42.990 MET: %C4K_REDUNDANCY-3-SIMPLEX_MODE: The peer Supervisor has been lost
Feb 16 00:12:08.000 MET: %C4K_REDUNDANCY-6-DUPLEX_MODE: The peer Supervisor has been detected
Feb 16 00:12:17.676 MET: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 3 (WS-X45-SUP6L-E S/N: JAE1411042P Hw: 1.1) is online
Feb 16 00:12:17.680 MET: %C4K_REDUNDANCY-6-MODE: ACTIVE supervisor initializing for sso mode
Feb 16 00:12:18.000 MET: %C4K_REDUNDANCY-3-COMMUNICATION: Communication with the peer Supervisor has been established
Feb 16 00:12:24.648 MET: %C4K_REDUNDANCY-5-CONFIGSYNC: The bootvar has been successfully synchronized to the standby supervisor
Feb 16 00:12:24.648 MET: %C4K_REDUNDANCY-5-CONFIGSYNC: The config-reg has been successfully synchronized to the standby supervisor
Feb 16 00:12:24.648 MET: %C4K_REDUNDANCY-5-CONFIGSYNC: The startup-config has been successfully synchronized to the standby supervisor
Feb 16 00:12:25.484 MET: %C4K_REDUNDANCY-5-CONFIGSYNC: The private-config has been successfully synchronized to the standby supervisor
Feb 16 00:12:27.176 MET: %C4K_REDUNDANCY-5-CONFIGSYNC_RATELIMIT: The vlan database has been successfully synchronized to the standby supervisor
Feb 16 00:12:50.556 MET: %HA_CONFIG_SYNC-6-BULK_CFGSYNC_SUCCEED: Bulk Sync succeeded
Feb 16 00:12:51.276 MET: %RF-5-RF_TERMINAL_STATE: Terminal state reached for (SSO)
Feb 16 04:14:15.551 MET: %C4K_REDUNDANCY-4-KEEPALIVE_WARNING: Keepalive messages from peer Supervisor are missing for 27 seconds
Feb 16 04:14:30.955 MET: %C4K_REDUNDANCY-3-COMMUNICATION: Communication with the peer Supervisor has been lost
Feb 16 04:14:30.963 MET: %C4K_REDUNDANCY-3-SIMPLEX_MODE: The peer Supervisor has been lost
Feb 16 04:16:54.970 MET: %C4K_REDUNDANCY-6-DUPLEX_MODE: The peer Supervisor hasbeen detected
Feb 16 04:17:04.962 MET: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 3 (WS-X45-SUP6L-E S/N: JAE1411042P Hw: 1.1) is online
Feb 16 04:17:04.962 MET: %C4K_REDUNDANCY-6-MODE: ACTIVE supervisor initializing for sso mode
Feb 16 04:17:04.970 MET: %C4K_REDUNDANCY-3-COMMUNICATION: Communication with the peer Supervisor has been established
Feb 16 04:17:11.766 MET: %C4K_REDUNDANCY-5-CONFIGSYNC: The bootvar has been successfully synchronized to the standby supervisor
Feb 16 04:17:11.766 MET: %C4K_REDUNDANCY-5-CONFIGSYNC: The config-reg has been successfully synchronized to the standby supervisor
Feb 16 04:17:11.770 MET: %C4K_REDUNDANCY-5-CONFIGSYNC: The startup-config has been successfully synchronized to the standby supervisor
Feb 16 04:17:12.590 MET: %C4K_REDUNDANCY-5-CONFIGSYNC: The private-config has been successfully synchronized to the standby supervisor
Feb 16 04:17:14.354 MET: %C4K_REDUNDANCY-5-CONFIGSYNC_RATELIMIT: The vlan database has been successfully synchronized to the standby supervisor
Feb 16 04:17:37.746 MET: %HA_CONFIG_SYNC-6-BULK_CFGSYNC_SUCCEED: Bulk Sync succeeded
Feb 16 04:17:38.446 MET: %RF-5-RF_TERMINAL_STATE: Terminal state reached for (SSO)
Feb 16 09:21:24.884 MET: %C4K_REDUNDANCY-5-CALENDAR_RATELIMIT: The calendar hasbeen successfully synchronized to the standby supervisor24 times since last calendar syslog
All the days I get always the same log message (see the bold character)
Is a hardware problem of WS-X45-SUP6L-E on module 3 ???
Can you help me ??
By
Crsitian
02-20-2013 02:24 AM
Hi Cristian,
From the logs seen on your device:Feb 16 00:09:33.137 MET: %C4K_REDUNDANCY-4-KEEPALIVE_WARNING: Keepalive messages from peer Supervisor are missing for 27 seconds
The Default keep-alive timer value is nine seconds and Default keep-alive threshold value is 18 seconds. This means that keep-alive messages are sent every nine seconds and it is allowed to miss a total of 18 keep-alive messages before it declares that something is wrong. This gives a total of 162 seconds or 2.7 mins of keep-alive timeout. It is possible that the Supervisor is too busy to handle keepalive. In some scenarios, the logs says that the system returned to ROM by Stateful Switchover. In redundant systems, after 162 seconds the switch triggers a redundancy failover. In most of these cases, this is a transient issue which happens only once. As a workaround, you can reseat the Primary Supervisor module and then force it to become active and then monitor the switch for further error messages.
Inayath
*Plz rate the usefull posts.
02-20-2013 02:35 AM
look :
Communications = Up
The supervisor in solt 3 restart alone see uptime.
I opend a case on TAC, and the response is that the module is faulty
02-20-2013 02:39 AM
Hi Cris,
I didnt had a look at the crash info of the module hence didnt suggest the module to be replaced.
REgard
Inayath
