Problem on telnet connection
ZAMSONI65
Community Member
Hi, sometime I've a problem when i try to connect to a cisco router with a telnet. I try starting a telent session and the router answer back with a triple request of username but immediately after i receive the information that the connection has been "...closed by foreign host"
This behavior is not constant, other time the session goes well. i also saw that the destination router is not overloaded in this period
Georg Pauwen
what does the VTY line config look like ? It should be something like this:
line vty 0 15
password yourpassword
transport input telnet
login
Very long uptimes can sometimes also be a problem. Check the uptime of your router with:
show version | i uptime
Yes the config is similar and the system should stay up always..
line vty 0 4
 exec-timeout 5 0
 login local
 transport input telnet ssh
line vty 5 15
 exec-timeout 5 0
 login local
till now is:
uptime is 34 weeks, 6 days, 33 minutes
try to configure a password on the vty lines and check if that makes a difference...
But I have a username and password configured locally, and usually doesn't produce problems, similar to this:
3560#sh run
Building configuration...
service password-encryption
username ABCDE password 7 12345abc
