Problem Ping PC extrange
farguisito
Level 3
Level 3
I have a problem that I don´t undertand that is happening in my network.
I have one architecture like the bottom picture. PC1 and PC2 have internet. However when I do one ping from PC1 to PC2 I have no answer. If I do one ping from L3 switch to PC2 I has ping.
Which could be the problem?
Regards.
These are the route and AC list.
S*    0.0.0.0/0 [1/0] via 10.0.0.254
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        10.0.0.0/16 is directly connected, Vlan2
L        10.0.0.1/32 is directly connected, Vlan2
      172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
C        172.16.0.0/16 is directly connected, Vlan10
L        172.16.0.254/32 is directly connected, Vlan10
      172.17.0.0/16 is variably subnetted, 2 subnets, 2 masks
C        172.17.0.0/16 is directly connected, Vlan20
L        172.17.0.254/32 is directly connected, Vlan20
      172.18.0.0/16 is variably subnetted, 2 subnets, 2 masks
C        172.18.0.0/16 is directly connected, Vlan30
L        172.18.0.254/32 is directly connected, Vlan30
C     192.168.0.0/16 is directly connected, Vlan1
      192.168.1.0/32 is subnetted, 1 subnets
L        192.168.1.1 is directly connected, Vlan1
Standard IP access list 1
    10 permit 192.168.0.0, wildcard bits 0.0.255.255
    20 permit 172.16.0.0, wildcard bits 0.0.255.255
    30 permit 172.17.0.0, wildcard bits 0.0.255.255
    40 permit 10.0.0.0, wildcard bits 0.0.255.255
    50 permit 172.18.0.0, wildcard bits 0.0.255.255
Standard IP access list 23
    10 permit 192.168.0.0, wildcard bits 0.0.255.255 (16 matches)
    40 permit 10.0.0.0, wildcard bits 0.0.255.255 (2 matches)
Extended IP access list preauth_ipv4_acl (per-user)
    10 permit udp any any eq domain
    20 permit tcp any any eq domain
    30 permit udp any eq bootps any
    40 permit udp any any eq bootpc
    50 permit udp any eq bootpc any
    60 deny ip any any
IPv6 access list preauth_ipv6_acl (per-user)
    permit udp any any eq domain sequence 10
    permit tcp any any eq domain sequence 20
    permit icmp any any nd-ns sequence 30
    permit icmp any any nd-na sequence 40
    permit icmp any any router-solicitation sequence 50
    permit icmp any any router-advertisement sequence 60
    permit icmp any any redirect sequence 70
    permit udp any eq 547 any eq 546 sequence 80
    permit udp any eq 546 any eq 547 sequence 90
    deny ipv6 any any sequence 100
NaveNueva#sh vtp status
VTP Version capable             : 1 to 3
VTP version running             : 1
VTP Domain Name                 :
VTP Pruning Mode                : Disabled
VTP Traps Generation            : Disabled
Device ID                       : 58ac.7899.9980
Configuration last modified by 192.168.1.1 at 9-28-17 13:55:37
Local updater ID is 192.168.1.1 on interface Vl1 (lowest numbered VLAN interface found)
Feature VLAN:
VTP Operating Mode                : Server
Maximum VLANs supported locally   : 1005
Number of existing VLANs          : 11
Configuration Revision            : 8
MD5 digest                        : 0xDC 0x0A 0x56 0x0B 0x41 0x44 0x23 0xD6
                                    0xD4 0x68 0xA0 0x47 0x5B 0x97 0xD3 0x01
NaveNueva#show interface gig 1/0/10 trunk
Port        Mode             Encapsulation  Status        Native vlan
Gi1/0/17    on               802.1q         trunking      1
Port        Vlans allowed on trunk
Gi1/0/17    1-3,10,20,30,40,50,1002-1005
Port        Vlans allowed and active in management domain
Gi1/0/17    1-2,10,20,30
Port        Vlans in spanning tree forwarding state and not pruned
10 Replies 10
 I did not find the picture. The configuration from devices is also too difficult to read. Put as txt attached or  insert as code by using the simble </> above.
Also, send me the route table from both PC.
-If I helped you somehow, please, rate it as useful.-
I can see the picture and I have the text between </>. I don´t know what is the problem in the topic.
Seb Rupik
Hi there,
Is PC1 using the linksys router as its default gateway (10.0.0.254) ? If so, does that router have a route to VLAN1 ? Something like:
ip route 192.168.0.0 255.255.0.0 10.0.0.1
cheers,
Seb.
PC1 has 10.0.0.1 gateway and PC2 has 192.168.1.1
Thanks for the help.
I have these sentence in the Switch L3
ip route 0.0.0.0 0.0.0.0 10.0.0.254
What is the output for:
sh ip arp vlan 1
sh ip arp vlan 2
sh mac add  | inc 1/0/5
sh mac add  | inc 1/0/10
cheers,
Seb.
The output is the next ( I have summaried it)
Switch#sh mac add | include 1/0/5
   2    547c.6946.ef30    DYNAMIC     Gi1/0/5
Switch#sh mac add | include 1/0/10
   2    fcaa.14ce.8a9e    DYNAMIC     Gi1/0/8
Switch#sh ip arp vlan 2
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.0.0.1                -   58ac.7899.99f7  ARPA   Vlan2
Internet  10.0.0.254              0   c056.2773.3167  ARPA   Vlan2
Internet  10.0.0.71             137   fcaa.14ce.8a9e  ARPA   Vlan2
NaveNueva#sh ip arp vlan 1
Internet  192.168.11.100          0   0024.9b23.04dd  ARPA   Vlan1
It seems all right, doesn't it?
Anybody think something about this issue, please?
This output looks to have been edited too much! 🙂
Shows a mac address on 1/0/8
Also I assume the output was all gathered on the same L3 switch (3560), but the hostname changes from Switch to NaveNueva .
Can you provide the following output (un-summarised):
sh mac add dyn vlan 1
sh mac add dyn vlan 2
sh ip arp vlan 1
sh ip arp vlan 2
Also what are the MAC addresses of PC1 and PC2?
cheers,
Seb.
Yes, I have edited fastly becouse I had changed the PC's port and I want to keep the picture scenario.
Now it is the port 8.
NaveNueva#sh mac add | include 1/0/8
Yes, I forget edit the name of NaveNueva to Switch sorry.
   1    0024.9b23.04dd    DYNAMIC     Gi1/0/17
(This is my Mac PC 1)
.sh mac add dyn vlan 2
(This is Mac PC 2)
sh ip arp vlan 1
(PC  1 ip)
sh ip arp vlan 2
Internet  10.0.0.71              34   fcaa.14ce.8a9e  ARPA   Vlan2
(PC 2 ip)
Regards.
