problem pinging network
Eric.Biggie
Hello all,  I'm having a problem pinging a network and would appreciate some help .
I have a router setup with fa0/0: 10.20.30.109 /24.  and fa0/1: 172.16.1.1 /24.  using rip v2.   Any device on the 172.16.1.0 network can ping anything on the 10.20.30.0 network just fine, but vice versa doesn't work?
here's the show ip route:
Router#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 10.20.30.1 to network 0.0.0.0
     172.16.0.0/24 is subnetted, 1 subnets
C       172.16.1.0 is directly connected, FastEthernet0/1
     10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C       10.20.30.0/24 is directly connected, FastEthernet0/0
S       10.0.0.0/8 [1/0] via 10.20.30.0
S*   0.0.0.0/0 [1/0] via 10.20.30.1
Router#
any thoughts on why I can't ping the 172.16.1.0 network from the 10.20.30.0 network?  any help is much appreciated..
E.
8 Replies 8
Antonio Knox
Level 7
Level 7
Is there an ACL involved?  Either that or an incorrect default gateway configured on the 10.20.30.x network?  Can you post a config?
Hello, thanks for your reply .  Here's the show run (less phone numbers, etc..):
Router#show run
Building configuration...
Current configuration : 10084 bytes
! Last configuration change at 19:26:03 GERMANY Thu Jul 21 2011
! NVRAM config last updated at 19:20:23 GERMANY Thu Jul 21 2011
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
clock timezone GERMANY 1
no network-clock-participate slot 1
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 172.16.1.1 172.16.1.25
ip dhcp excluded-address 172.16.1.51 172.16.1.254
ip dhcp pool VOICE
   network 172.16.1.0 255.255.255.0
   default-router 172.16.1.1
   dns-server 4.2.2.2
   option 150 ip 172.16.1.1
   domain-name wr
ip name-server 10.20.30.1
voice-card 1
no dspfarm
archive
log config
  hidekeys
interface FastEthernet0/0
ip address 10.20.30.109 255.255.255.0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
clock rate 2000000
interface FastEthernet0/1
ip address 172.16.1.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
interface FastEthernet2/0
switchport mode trunk
spanning-tree portfast
interface FastEthernet2/1
interface FastEthernet2/2
interface FastEthernet2/3
interface FastEthernet2/4
interface FastEthernet2/5
interface FastEthernet2/6
interface FastEthernet2/7
interface FastEthernet2/8
interface FastEthernet2/9
interface FastEthernet2/10
interface FastEthernet2/11
interface FastEthernet2/12
interface FastEthernet2/13
interface FastEthernet2/14
interface FastEthernet2/15
interface Vlan1
no ip address
router rip
version 2
passive-interface FastEthernet0/0
passive-interface FastEthernet0/1
passive-interface Vlan1
network 10.0.0.0
network 172.16.0.0
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.20.30.1
ip route 10.0.0.0 255.0.0.0 10.20.30.0
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:/cme-full-7.0.0.1/GUI
ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 172.16.1.0 0.0.0.255
tftp-server flash:/cme-full-7.0.0.1/PHONE/7940-7960/P00308000500.bin alias P00308000500.bin
tftp-server flash:/cme-full-7.0.0.1/PHONE/7940-7960/P00308000500.loads alias P00308000500.loads
tftp-server flash:/cme-full-7.0.0.1/PHONE/7940-7960/P00308000500.sb2 alias P00308000500.sb2
tftp-server flash:/cme-full-7.0.0.1/PHONE/7940-7960/P00308000500.sbn alias P00308000500.sbn
tftp-server flash:/cme-full-7.0.0.1/PHONE/7920/cmterm_7920.4.0-03-02.bin alias cmterm_7920.4.0-03-02.bin
tftp-server flash:/cme-full-7.0.0.1/PHONE/7970-7971/apps70.8-3-2-27.sbn alias apps70.8-3-2-27.sbn
tftp-server flash:/cme-full-7.0.0.1/PHONE/7970-7971/cnu70.8-3-2-27.sbn alias cnu70.8-3-2-27.sbn
tftp-server flash:/cme-full-7.0.0.1/PHONE/7970-7971/cvm70sccp.8-3-2-27.sbn alias cvm70sccp.8-3-2-27.sbn
tftp-server flash:/cme-full-7.0.0.1/PHONE/7970-7971/dsp70.8-3-2-27.sbn alias dsp70.8-3-2-27.sbn
tftp-server flash:/cme-full-7.0.0.1/PHONE/7970-7971/jar70sccp.8-3-2-27.sbn alias jar70sccp.8-3-2-27.sbn
tftp-server flash:/cme-full-7.0.0.1/PHONE/7970-7971/SCCP70.8-3-3S.loads alias SCCP70.8-3-3S.loads
tftp-server flash:/cme-full-7.0.0.1/PHONE/7970-7971/term70.default.loads alias term70.default.loads
tftp-server flash:/cme-full-7.0.0.1/PHONE/7970-7971/term71.default.loads alias term71.default.loads
tftp-server flash:/cme-full-7.0.0.1//ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/cme-full-7.0.0.1//ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/Bass.raw alias Bass.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/Chime.raw alias Chime.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/Pop.raw alias Pop.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/RingList.xml alias RingList.xml
tftp-server flash:/cme-full-7.0.0.1//ringtones/louda1.raw alias louda1.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/loudc1.raw alias loudc1.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/loudc2.raw alias loudc2.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/loudcl1.raw alias loudcl1.raw
tftp-server flash:/cme-full-7.0.0.1//ringtones/loudlaser.raw alias loudlaser.raw
control-plane
voice-port 1/0/0
voice-port 1/0/1
voice-port 1/1/0
supervisory disconnect dualtone mid-call
cptone DE
timeouts call-disconnect 1
timeouts ringing 5
timeouts wait-release 1
connection plar 2820
impedance complex2
caller-id enable
voice-port 1/1/1
cptone DE
timeouts ringing 5
connection plar 2834
impedance complex2
caller-id enable
voice-port 1/1/2
cptone DE
timeouts ringing 5
connection plar opx 2023
impedance complex2
caller-id enable
voice-port 1/1/3
cptone DE
timeouts ringing 5
connection plar opx 821707
impedance complex2
caller-id enable
dial-peer voice 3301 pots
destination-pattern 3301
port 1/0/0
dial-peer voice 100 pots
description outgoing to 2820 line
destination-pattern .T
port 1/1/0
forward-digits all
dial-peer voice 101 pots
port 1/1/1
forward-digits all
dial-peer voice 102 pots
port 1/1/2
forward-digits all
dial-peer voice 103 pots
port 1/1/3
forward-digits all
gatekeeper
shutdown
telephony-service
load 7960-7940 P00308000500
load 7920 cmterm_7920.4.0-03-02
load 7970 SCCP70.8-3-3S
max-ephones 16
max-dn 32
ip source-address 172.16.1.1 port 2000
service phone backlightIdleTimeout 01:00
timeouts interdigit 3
system message Biggie Telephone Network
url services http://phone-xml.berbee.com/menu.xml
max-conferences 8 gain -6
moh flash:/cme-full-7.0.0.1/music-on-hold.au
web admin system name cisco password cisco
dn-webedit
time-webedit
transfer-system full-consult
directory entry 1 **
directory entry 2 **
directory entry 3 **
directory entry 4 **
directory entry 5 **
create cnf-files version-stamp 7960 Jan 20 2011 19:03:32
ephone-dn  1  dual-line
number 2820 secondary **
ephone-dn  2  dual-line
number 2834 secondary **
ephone-dn  3  dual-line
number 2023 secondary **
ephone-dn  4  dual-line
number 2847 secondary **
ephone-dn  5  dual-line
number 821707 secondary **
ephone  1
device-security-mode none
description 7960 phone
mac-address 0003.E3B9.****
button  1:1
ephone  2
description 7970 phone
mac-address 0018.18D7.****
button  1:1 2:2 3:3 4:4
button  5:5
ephone  3
mac-address 0014.6AB7.****
button  1:3 2f5
ephone  4
mac-address 0014.A998.****
button  1:1 2f3
ephone  5
mac-address 0014.A8A7.****
button  1:5
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
ntp clock-period 17180814
ntp master
ntp server 131.188.3.220
end
Router#
Is there a router connected to Fa0/0?  If so, this may be a problem:
router rip
If there's a router connected to Fa0/0, he won't know about how to get to 172.16.1.0/24 since Fa0/0 isn't sending him route information telling him "Hey I'm the next hop to 172.16.1.0/24!!!".
Message was edited by: Antonio Knox
Hi Antonio,  I removed passive-interface FastEthernet0/0 and I still can't ping 172.16.1.1 from a pc on the 10.20.30.1 network.
Yes there is a router connected to fa0/0.  It's my home DSL router, a Cisco RV110W.  I have a small switch and a few pc's connected to the RV110W.
I have fa0/1 port configured for 172.16.1.1 and I have that directly connected to a NM-16esw w/PoE supporting IP phones, wireless, etc..  All the phones, etc. are working and register with CME. There's no problem on the Voice support.
In the past I never needed to connect to the 172.16.1.0 network, but now I want to VPN a tunnel to another CME router. Hence, why I found out I can't ping the 172.16.1.1 from my next hop?
V/r,
Eric
Eric
What is the default-gateway set to on the 10.20.30.x clients ?
I suspect the issue is because you are natting your 172.16.1.x clients to the fa0/0 ip address of 10.20.30.109 so the ping works that way because clients in 10.20.30.x simply send packets back to the router.
But when you ping from 10.20.30.x the clients send their packets to their default-gateway which is another L3 device which doesn't have a route to the 172.16.1.0/24 network.
Jon
Are you running a routing protocol on the RV110W or does he just have a default route?
Hello Jon,
the 10.20.30.x router is a Cisco RV110W.  It's just a small home router with HTML interface setup, etc.  In the networking tab it has an option to pick "gateway" or "router".  It's set for gateway right now but has RIPv2 enabled automatically. I'll have to check if I can add 172.16... in the route table manually.
It looks like this is most likely the problem. Before I change anything on the RV110W, I'll setup another spare router, but a 2600 or something and see if I can route to the 172 network that way first. Then I'll definately know if it's the RV110W.
Thanks, and I'll post back the results.
V/r,
Eric
Here's a diagram of the network:
Ok, I couldn't get the extra lab router to work correctly either.   I did however figure out how to add entries in the RV110W routing table.  I eventually added a loopback interface 172.16.2.100 on the 3725 CME voice router, and added networks 172.16.2.0 and 172.16.1.0 in the RV110W routing table.  I was then able to ping the 172.16.2.. loopback, but still nothing on the voice network 172.16.1..   So then I started removing services and found out that when NAT is disabled, I can successfully ping 172.16.1.1.  All I have to do is remove "access-list 1 permit 172.16.2.0 0.0.0.255" from the running config.
However this obviously causes another problem.  Any thoughts on how I can remedy this?
A big Thank you in advance,
Eric
