Problem Programming Catalyst 2960x
PNKTech1
Community Member
I'm encountering a problem getting a Cisco 2960x to accept a line of programming. I'm setting it up currently:
Switch#config t
switch(config)#hostname 3560_10
3560_10(config)#enable secret zxcvbnm
3560_10(config)#enable password cisco
3560_10(config)#line con 0
3560_10(config-line)#password cisco
3560_10(config-line)#login
3560_10(config-line)#exit
3560_10(config)#line vty 0 4
3560_10(config)#line vty 5 15
3560_10(config)#service password-encryption
3560_10(config)#vlan 10
3560_10(config-vlan)#name Surveillus
3560_10(config-vlan)#exit
3560_10(config)#interface vlan 1
3560_10(config-if)#ip address 10.20.85.20 255.255.0.0
3560_10(config-if)#no shutdown
3560_10(config-if)#exit
3560_10(config)#spanning-tree mode pvst
3560_10(config)#interface port-channel10
3560_10(config-if)#switchport mode trunk
3560_10(config)#interface range gigabitethernet0/1 - 48
% Invalid input detected at '^' marker.
3560_10(config-if-range)#switchport access vlan 10
3560_10(config-if-range)#switchport mode access
3560_10(config-if-range)#spanning-tree portfast
3560_10(config-if-range)#exit
3560_10(config)#interface range gigabitethernet0/49 - 52
3560_10(config-if-range)#switchport mode trunk
3560_10(config)#interface range gigabitethernet0/51 - 52
3560_10(config-if-range)#channel-group 10 mode active
3560_10(config-if-range)#end
3560_10#clock set 09:50:00 26 dec 2017
3560_10#wr mem
The line in bold is the one that won't take. The error arrow is pointing to the 0 in case formatting sets it off. Not sure why it won't take the command. Any useful advice would be much appreciated.
Thank you!
7 Replies 7
tredgrove
Level 2
Level 2
first thought was whether the switch was in a stack -   are all the ports set with the same properties? for range to work all the ports have to have the same base config.  might trigger a thought from another. watching.
The switch is not in a stack, but the 3750's that are next in the chain are, but I don't think that matters does it?
Joseph W. Doherty
Hmm, looks right - i.e. one would expect it to work. What's the IOS image?
For ha ha's sake, you might also try "int range g0/1 - 48" or "int range g 0/1 - 48".
BTW
for:
I would recommend you use:
spanning-tree mode rapid-pvst
also rather for access interfaces':
you might use instead (global):
spanning-tree portfast default
spanning-tree portfast bpduguard default
Ben Walters
Level 9
Level 9
It looks like you might be missing some part of the interface identifier, if you do a sho int status it should give you the correct format for your interface numbers in the port column.
For the 2960x switches we have deployed interfaces are listed as X/0/1-48 with X being the switch number in the stack which starts at 1.
If you have just the one switch the correct command should be
int range gigabitEthernet 1/0/1-48
Ben is correct.
The command for a single switch would be...
int range gi1/0/1 - 48
Mike
Ben and Mike, yea a switch number on the interface would make sense except for OP showing range g0/49 - 52 and g0/51 - 52 appeared to have been accepted.
The 2960X's I have configured show this as the interface
interface GigabitEthernet1/0/5
Also the above was for a 3560 I think, or at least the host name was setup that way.
If he would post the output of show run for one of the interfaces we would be able to help.
Mike
