06-10-2018 08:53 AM - edited 03-08-2019 03:19 PM
Hi, i have two switch connected each other with a trunk. the first switch has ip 192.168.1.11 and the secondo 192.168.1.13.
The first switch has two trunk, one connected to the core and one connected to the second switch. The second switch has only one trunk connected to the first switch
CORE-----Switch1-----Switch2
the core switch has ip 192.168.1.1
the config of the first switch is the following:
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname switch11
enable password 7 xxxxxxxxxxxxx
username xxxxx privilege 15 password 7 xxxxxxxxxxxx
no aaa new-model
clock timezone ITALY 1
clock summer-time ITALY recurring last Sun Mar 2:00 last Sun Oct 3:00
ip subnet-zero
no ip domain-lookup
no file verify auto
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
 switchport access vlan 2
 switchport mode access
 spanning-tree portfast
interface FastEthernet0/2
interface FastEthernet0/46
 switchport voice vlan 5
interface FastEthernet0/47
interface FastEthernet0/48
interface GigabitEthernet0/1
 switchport mode trunk
 switchport nonegotiate
interface GigabitEthernet0/2
interface Vlan1
 no ip address
 no ip route-cache
 shutdown
interface Vlan2
 ip address 192.168.1.11 255.255.255.0
 no ip route-cache
ip default-gateway 192.168.1.1
ip http server
snmp-server community public RO
control-plane
line con 0
 logging synchronous
 login local
line vty 0 4
 logging synchronous
 login local
line vty 5 15
 logging synchronous
 login local
end
The second switch has the below config:
version 12.2
no service pad
hostname switch13
boot-start-marker
boot-end-marker
enable password xxxxxxxxx
username administrator privilege 15 secret 5 xxxxxxxxxxxxxxxxx
username xxxxxxxxx privilege 15 password 0 xxxxxxxxxxx
no aaa new-model
system mtu routing 1500
no ip domain-lookup
crypto pki trustpoint TP-self-signed-3343221248
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3343221248
 revocation-check none
 rsakeypair TP-self-signed-3343221248
crypto pki certificate chain TP-self-signed-3343221248
 certificate self-signed 01
 30820248 308201B1 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
xxxxxxxxxxxxxxxxxxxxxxx
quit
interface FastEthernet0/24
interface Vlan1
 no ip address
 no ip route-cache
 shutdown
interface Vlan2
 ip address 192.168.1.13 255.255.255.0
 no ip route-cache
ip http server
ip http secure-server
line con 0
 logging synchronous
 login local
line vty 0 4
 logging synchronous
 login local
line vty 5 15
 logging synchronous
 login local
end
the two switch are connected through one gigabit cable connect from gi0/2 to gi0/2
if i run show cdp neigh in the first switch i can see the second switch but i'm unable to ping or telnet to the second switch from the coreswitch or from the first switch. no ping. no telnet
whats' wrong.
Can you help me?
regards
Solved! Go to Solution.
06-10-2018 12:08 PM
06-10-2018 12:08 PM
06-10-2018 02:08 PM
Are both interface g0/2 in up and up mode?
Also, can you add these 2 commands to both switches and test again?
no switchport nonegotiate
Depending on the IOS, the second command maybe default.
06-10-2018 10:25 PM - edited 06-10-2018 10:27 PM
Hi all and thanks, today i'll post show VLAN.
I don't think a problem about Trunk encap or other because all devices attached ti the second switch works and cani pass through the switch. The only problem is the ip management of the VLAN 2
06-10-2018 11:40 PM
the command "show vlan" gave me the solution. There is no vlan 2 configured so the interface vlan2 is down. thanks to all.
