Problem understanding RIP (v1 vs. v2)
kip
One of my students create the attached diagram.
It uses RIP (v1 AFAIK) and for some odd reason, every PC can ping all the others. The way I understand RIP v1, this shouldn't be possible when using subnetting. What's wrong/right?
Jon Marshall
You may get help if you post as just an image file.
Jon
Julio E. Moisa
Yes, it should be a problem because it change the subnet mask to "native" example: /8, /16 and /24 into the routing table but on the attached scenario you are using different subnets behind the routers, that is the reason why you are able to make ping between the hosts, each router has 3 different subnets on their routing tables:
192.168.0.0/24
192.168.2.0/24
192.168.3.0/24
Note: The real mask is not included on the routing table, it was replaced by the native /24 because you are using RIP version 1.
There are no any problem because they are 3 different subnets so they are able to ping without any inconvenience but imagine the following scenario:
If you are using for example a subnet 192.168.1.0/24 and a subnetting is done and as result you configure the following subnets:
192.168.1.0/26 for R1
192.168.1.64/26 for R2
192.168.1.128/26 for R3
You will have problems, because the routers will not able to see the difference because for RIP v1 they look like 192.168.1.0/24, because v1 is classful, so the routers will learn via RIP other different subnets than 192.168.1.X/X. So you will not be able to see the subnets from each others.
Please let me share an example:
R4 ----- R1  ------ R2  ----- R3
R4 Configuration
interface FastEthernet0/0
ip address 192.168.1.2 255.255.255.128
duplex auto
speed auto
router rip
version 1
network 192.168.1.0
R4#SH IP ROUTE
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
R 10.0.0.0/8 [120/1] via 192.168.1.1, 00:00:16, FastEthernet0/0
192.168.1.0/25 is subnetted, 1 subnets
C 192.168.1.0 is directly connected, FastEthernet0/0
R1 Configuration
ip address 192.168.1.1 255.255.255.128
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.12.0.1 255.255.255.0
duplex auto
speed auto
router rip
version 1
network 10.0.0.0
network 192.168.1.0
R1#SH IP ROUTE
10.0.0.0/24 is subnetted, 1 subnets
C 10.12.0.0 is directly connected, FastEthernet0/1
R1#
R2 Configuration
ip address 192.168.1.129 255.255.255.128
duplex auto
speed auto
ip address 10.12.0.2 255.255.255.0
duplex auto
speed auto
router rip
version 1
network 10.0.0.0
network 192.168.1.0
R2#sh ip route
C 192.168.1.128 is directly connected, FastEthernet0/0
R3 Configuration
ip address 192.168.1.130 255.255.255.128
duplex auto
speed auto
router rip
version 1
network 192.168.1.0
R3#sh ip route
R 10.0.0.0/8 [120/1] via 192.168.1.129, 00:00:10, FastEthernet0/0
From R1
R1#sh ip route 192.168.1.129
% Subnet not in table
R1#sh ip route 192.168.1.130
Routing entry for 192.168.1.0/25
Known via "connected", distance 0, metric 0 (connected, via interface)
Redistributing via rip
Advertised by rip
Routing Descriptor Blocks:
* directly connected, via FastEthernet0/0
Route metric is 0, traffic share count is 1
R1#sh ip route 192.168.1.2
Advertised by rip
R1#
In few words the R1 knows the connected subnets and the point to point subnet only but not the subnet behind R2. R3 and R4 will only know the Point to point subnet between R1 and R2 but not other ones.
R4#sh ip route
R 10.0.0.0/8 [120/1] via 192.168.1.1, 00:00:10, FastEthernet0/0
R4#
R4#
R4#sh ip route 192.168.1.130
R4#
R4#sh ip route 192.168.1.129
R4#
R3#sh ip route
R 10.0.0.0/8 [120/1] via 192.168.1.129, 00:00:05, FastEthernet0/0
R3#
R3#
R3#sh ip route 192.168.1.1
R3#
R3#sh ip route 192.168.1.2
If you configure each router with RIP ver 2 with no auto-summary, you will be able to see the other subnets.
R1 Config with version 2
duplex auto
speed auto
duplex auto
speed auto
router rip
version 2
network 10.0.0.0
network 192.168.1.0
no auto-summary
ip forward-protocol nd
R1#sh ip route
192.168.1.0/25 is subnetted, 2 subnets
R 192.168.1.128 [120/1] via 10.12.0.2, 00:00:21, FastEthernet0/1
R1#
Routing entry for 192.168.1.128/25
Known via "rip", distance 120, metric 1
Last update from 10.12.0.2 on FastEthernet0/1, 00:00:04 ago
* 10.12.0.2, from 10.12.0.2, 00:00:04 ago, via FastEthernet0/1
Route metric is 1, traffic share count is 1
R1#
Last update from 10.12.0.2 on FastEthernet0/1, 00:00:08 ago
* 10.12.0.2, from 10.12.0.2, 00:00:08 ago, via FastEthernet0/1
R1#
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
