Problem upgrading IOS on Cisco 2960X switches
Not applicable
I followed Cisco's recommendation on upgrading IOS on 2960X switch
switch1#archive download-sw /overwrite /reload tftp:192.168.0.1/c2960x-universalk9-tar.152-2.E6.tar
I am using SolarWinds TFTP server
It deleted the old IOS and replaced it with the new one, however, the new IOS is corrupted, I am doing a recovery via XModem.
Would you recommend doing it this way or the old way
switch1#copy tftp:192.168.0.1/c2960x-universalk9-tar.152-2.E6.tar flash:
Also would you use the .tar file or the .bin file??
Thank you.
5 Replies 5
Leo Laohoo
Did you compare the MD5 hash value of the downloaded file against the MD5 hash value found in the Cisco website?
This syntax won't work in ROMmon.
You could try copying the BIN file into a USB flash drive and forcing the switch (in ROMmon) to boot IOS from the USB flash drive using the command "boot usbflash0:IOS_filename.bin".
Once the switch boots up, then use "archive download-sw usbflash0:IOS_filename.tar" to unpack the TAR file into the switch and perform error check before terminating the process.
Not applicable
I ended up using XModem to transfer the IOS to the flash then set the switch to boot system flash:\filename
Will usbflash0: work if you are in
switch:
mode?
Michael
Will usbflash0: work if you are in ROMmon mode?
Yes it does/will.  I can attest to that because I've recovered several switches using the same method.
Not applicable
My issue with USB drive was the wrong format, I was informed to format it FAT32 instead of NTFS which I originally had.  Once I formatted it FAT32, the switch recognized the USB drive.  Thank you so much for your help
Not applicable
Thank you very much for your help, I didn't compare the MD5 hash value.  Thank you for the suggestion, I will try it from now on.
