problem VRRP, LACP Nexus 3048TP LAN1K9
JulianDD
Hi, i have problem of synced betewin my 2 switchs nexus 7.0.3.i7.3
I use feature BGP, LACP and VRRP (also VPC etc..)
But it's impossible of configure correctly the protocol
I have many errors :
One : In log :
%ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs 9-10 on Interface port-channel3 are being suspended. (Reason: peer-keepalive no
t operational, peer never alive)
I See that : https://quickview.cloudapps.cisco.com/quickview/bug/CSCvc06939
Two : show vrrpv3 brief
First switch (ok)
Vlan10 1 IPv4 100 0 N Y MASTER xxx.xxx.xxx.001(local) xxx.xxx.xxx.254
Second switch (missing ip?)
Vlan10 1 IPv4 100 0 N Y INIT AF-UNDEFINED xxx.xxx.xxx.254
Three : show vrrp
Switch 1 :
Vlan10 - Group 1 - Address-Family IPv4
State is MASTER
State duration 4 days 22 hours 19 mins
Virtual IP address is xxx.xxx.xxx.254
Virtual MAC address is 0000.5e00.0101
Advertisement interval is 1000 msec
Preemption enabled, delay min 30 secs (0 msec remaining)
Priority is 100
Master Router is xxx.xxx.xxx.254 (local), priority is 100
Master Advertisement interval is 1000 msec (expires in 629 msec)
Master Down interval is unknown
Switch 2 :
State is INIT (Interface Down)
State duration 19 mins 0.629 secs
Priority is 100
Master Router is unknown, priority is unknown
Master Advertisement interval is unknown
Four : sh vpc role
Switch 1 :
vPC role : primary
Dual Active Detection Status : 0
vPC system-mac : 00:23:04:ee:be:01
vPC system-priority : 32667
vPC local system-mac : 84:b8:02:92:31:bc
vPC local role-priority : 0
vPC local config role-priority : 1
vPC peer system-mac : 00:00:00:00:00:00
vPC peer role-priority : 0
vPC peer config role-priority : 0
Switch 2 :
vPC role : none established
vPC system-mac : 00:00:00:00:00:00
vPC local system-mac : a4:4c:11:6b:ca:bc
vPC local config role-priority : 2
Could you help me ?
Regars
Julian
JulianDD
Hi MHM,
I found solution!
BR2 Hardware is Dead ...
I replace by new switch and it's work.
58 Replies 58
balaji.bandi
what is port-channel 3 ?
Looks like you have vPC configuration issue, you need to post both the nexus configuration here:
show run
show cdp neigh
show vpc brief
show vpc role
show vpc peer-keepalive
check the vPC best practice, same for all nexus devices :
https://www.cisco.com/c/dam/en/us/td/docs/switches/datacenter/sw/design/vpc_design/vpc_best_practices_design_guide.pdf
BB
DanielP211
Please display all configuration regarding portchannel and vpc.
BR
****Kindly rate all useful posts*****
JulianDD
Thx Guys,
Show my 2 conf (switch br1 and br2)
Descriptions : My Br1 is work actually and no communicating to br2.
Also, at 24 april, i replace my BR2 material by same model and i uploaded my conf file backuped. But not work ...
Thank you for your support
Julian
peer-keepalive destination 10.0.0.1 source 10.0.0.0 vrf pka1
The source is 10.0.0.0 ???
MHM
Hi MHM,
Yes, the ip address 10.0.0.0 is br1, it's possible.
Julian
No friend
You use /31 for p2p and that not work
You need for keepalive
Four IP
One for each NSK
And one network Id and other broadcast IP
I.e. you need to use /30 at least
MHM
is that working before April 24 ?
Do you have high level rough diagram what ports connected each other ?
My observation on the config :
1. have you created VRF ? i do not see in the config that VRF context created.
create VRF context on both the switches :
vrf context pka1
vrf context management
2. i would suggest small changes on the config and test it (make sure some of the configuration you changing may have convergence,) so understand the config apply in the maintenance window.
BR1 :
vpc domain 1
role priority 1
peer-keepalive destination 10.0.0.2 source 10.0.0.1 vrf pka1
peer-switch
peer-gateway
auto-recovery
ipv6 nd synchronize
ip arp synchronize
interface Vlan9
description interco-routers
no shutdown
mtu 9216
ip address 10.0.0.9/29    -- this changed may be required associated config
interface port-channel2
description keepalive
no switchport
vrf member pka1
ip address 10.0.0.1/29
BR2:
vpc domain 1
role priority 2
peer-keepalive destination 10.0.0.1 source 10.0.0.2 vrf pka1
peer-switch
peer-gateway
auto-recovery
ipv6 nd synchronize
ip arp synchronize
interface Vlan9
no shutdown
mtu 9216
ip address 10.0.0.10/29
no switchport
vrf member pka1
ip address 10.0.0.2/29
Note : i am more focusing on bringing the VPC up before we can test other stuff
Also thinking that Layer 2 connection up and interface connected right port each other.
I have also requested other information as below :
show cdp neigh
show vpc brief
show vpc role
Also some reference ,my vPC testing :
https://www.balajibandi.com/?p=618
BB
Hi BB,
Yes work since 2018
Photo in datacenter about switchs (sorry for quality)
VRF here
ip route 0.0.0.0/0 192.168.0.254
vrf context pka1
description vPC1 keepalive
Tell me if you have questions.
Julian
that's fine - i did not find the information on your show run hence the question.
i would like to see below information if you need more assistance
 have also requested other information as below : from both the switches.
show cdp neigh
show vpc brief
show vpc role
show ip interface brief
EDIT- rather another post
how ip address 10.0.0.9/29 -- this changed may be required associated config ?
instead of /31 i changed IP address to /29 to be clear
BB
BR1
show cdp neigh
Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge
S - Switch, H - Host, I - IGMP, r - Repeater,
V - VoIP-Phone, D - Remotely-Managed-Device,
s - Supports-STP-Dispute
Device-ID Local Intrfce Hldtme Capability Platform Port ID
sw2(xxxxxxx) Eth1/45 120 R S s N3K-C3048TP-1 mgmt0
sw2(xxxxxxx) Eth1/46 120 R S I s N3K-C3048TP-1 Eth1/1
br2.domain.com(xxxxxxx)
Eth1/49 123 R S I s N3K-C3048TP-1 Eth1/49
Eth1/50 123 R S I s N3K-C3048TP-1 Eth1/50
show vpc brief
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 1
Peer status : peer link is down
vPC keep-alive status : Suspended (Destination IP not reachable)
Configuration consistency status : failed
Per-vlan consistency status : success
Configuration inconsistency reason: Consistency Check Not Performed
Type-2 inconsistency reason : Consistency Check Not Performed
vPC role : primary
Number of vPCs configured : 46
Peer Gateway : Enabled
Dual-active excluded VLANs : -
Graceful Consistency Check : Disabled (due to peer configuration)
Auto-recovery status : Enabled, timer is off.(timeout = 240s)
Delay-restore status : Timer is off.(timeout = 30s)
Delay-restore SVI status : Timer is off.(timeout = 10s)
Operational Layer3 Peer-router : Disabled
vPC Peer-link status
id Port Status Active vlans
1 Po3 up -
vPC status
Id Port Status Consistency Reason Active vlans
1001 Po1001 down failed Peer-link is down -
1002 Po1002 down failed Peer-link is down -
1003 Po1003 up success Type checks were 10
bypassed for the vPC
1004 Po1004 down failed Peer-link is down -
1005 Po1005 down failed Peer-link is down -
1006 Po1006 down failed Peer-link is down -
1007 Po1007 down failed Peer-link is down -
1008 Po1008 down failed Peer-link is down -
1009 Po1009 up success Type checks were 10
1010 Po1010 up success Type checks were 10
1011 Po1011 up success Type checks were 10
1012 Po1012 up success Type checks were 10
1013 Po1013 down failed Peer-link is down -
1014 Po1014 down failed Peer-link is down -
1015 Po1015 down failed Peer-link is down -
1016 Po1016 down failed Peer-link is down -
1017 Po1017 down failed Peer-link is down -
1018 Po1018 up success Type checks were 10
1019 Po1019 down failed Peer-link is down -
1020 Po1020 down failed Peer-link is down -
1021 Po1021 down failed Peer-link is down -
1022 Po1022 up success Type checks were 10
1023 Po1023 down failed Peer-link is down -
1024 Po1024 down failed Peer-link is down -
1025 Po1025 down failed Peer-link is down -
1026 Po1026 down failed Peer-link is down -
1027 Po1027 down failed Peer-link is down -
1028 Po1028 down failed Peer-link is down -
1029 Po1029 down failed Peer-link is down -
1030 Po1030 down failed Peer-link is down -
1031 Po1031 down failed Peer-link is down -
1032 Po1032 down failed Peer-link is down -
1033 Po1033 down failed Peer-link is down -
1034 Po1034 down failed Peer-link is down -
1035 Po1035 down failed Peer-link is down -
1036 Po1036 down failed Peer-link is down -
1037 Po1037 down failed Peer-link is down -
1038 Po1038 down failed Peer-link is down -
1039 Po1039 down failed Peer-link is down -
1040 Po1040 down failed Peer-link is down -
1041 Po1041 down failed Peer-link is down -
1042 Po1042 down failed Peer-link is down -
1043 Po1043 down failed Peer-link is down -
1044 Po1044 down failed Peer-link is down -
1045 Po1045 up success Type checks were 10
1046 Po1046 up success Type checks were 10
show vpc role
vPC Role status
vPC role : primary
PC Role status
vPC role : primary
--Send status : Success
--Last send at : 2024.05.06 23:15:57 606 ms
--Sent on interface :
--Receive status : Failed
--Last update from peer : (508793) seconds, (801) msec
vPC Keep-alive parameters
--Destination : 10.0.0.1
--Keepalive interval : 1000 msec
--Keepalive timeout : 5 seconds
--Keepalive hold timeout : 3 seconds
--Keepalive vrf : pka1
--Keepalive udp port : 3200
--Keepalive tos : 192
IP Interface Status for VRF "default"(1)
Interface IP Address Interface Status
Vlan9 10.0.0.2 protocol-down/link-down/admin-up
Vlan10 xxx.xxx.xxx.252 protocol-up/link-up/admin-up
Eth1/51 149.14.0.50 protocol-up/link-up/admin-up
BR2
br1.domain.com(xxxxxx)
Eth1/49 162 R S I s N3K-C3048TP-1 Eth1/49
Eth1/50 162 R S s N3K-C3048TP-1 Eth1/50
Total entries displayed: 2
show vpc brief
vPC domain id : 1
1 Po3 up -
vPC status
1003 Po1003 down failed Peer-link is down -
1009 Po1009 down failed Peer-link is down -
1010 Po1010 down failed Peer-link is down -
1011 Po1011 down failed Peer-link is down -
1012 Po1012 down failed Peer-link is down -
1018 Po1018 down failed Peer-link is down -
1022 Po1022 down failed Peer-link is down -
1045 Po1045 down failed Peer-link is down -
1046 Po1046 down failed Peer-link is down -
show vpc role
vPC Role status
--Last send at : 2024.05.06 23:19:08 295 ms
--Last update from peer : (562) seconds, (863) msec
--Destination : 10.0.0.4
Vlan9 10.0.0.3 protocol-down/link-down/admin-up
Vlan10 xxx.xxx.xxx.253 protocol-down/link-down/admin-up
Eth1/51 212.85.148.15 protocol-up/link-up/admin-up
Julian
I try with peer-switch and change mask and IP.
No result
Have you an other idea ?
Julian
JulianDD
Thank you for your answer,
So you want i change thoses values only ?
interface Vlan9
no shutdown
mtu 9216
ip address 10.0.0.3/30
no switchport
vrf member pka1
ip address 10.0.0.1/30
Julian
I think you confuse here
The keepalive is l3 port and it not need to be SVI and PO
Single link like
Gigabitethernet 0/0  is enough
And config will be in both Nexus
interface GigabitEthernet0/0
No switchport
no switchport
vrf member pka1
ip address 10.0.0.1/30 (10.0.0.2/30 for other NSk)
No shut
That it
MHM
