Problem VSS 6500
CPerezL0208
Good afternoon. I had a problem with VSS , causing the complete collapse of CORE, please help.
CORE-HCUA#show version
Cisco IOS Software, s2t54 Software (s2t54-ADVIPSERVICESK9-M), Version 15.1(2)SY, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Wed 04-Sep-13 12:37 by prod_rel_team
ROM: System Bootstrap, Version 12.2(50r)SYS2, RELEASE SOFTWARE (fc1)
 CORE-HCUA uptime is 3 days, 18 hours, 6 minutes
Uptime for this control processor is 3 days, 18 hours, 13 minutes
System returned to ROM by power on
System restarted at 17:42:03 CL Mon Aug 31 2015
System image file is "bootdisk:s2t54-advipservicesk9-mz.SPA.151-2.SY.bin"
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (M8572) processor (revision ) with 1785856K/262144K bytes of memory.
Processor board ID SMG1644N02C
 CPU: MPC8572_E, Version: 2.2, (0x80E80022)
 CORE: E500, Version: 3.0, (0x80210030)
 CPU:1500MHz, CCB:600MHz, DDR:600MHz
 L1:    D-cache 32 kB enabled
        I-cache 32 kB enabled
Last reset from power-on
25 Virtual Ethernet interfaces
212 Gigabit Ethernet interfaces
40 Ten Gigabit Ethernet interfaces
2543K bytes of non-volatile configuration memory.
CORE-HCUA#
CORE-HCUA#show switch virtual
Switch mode                  : Virtual Switch
Virtual switch domain number : 100
Local switch number          : 1
Local switch operational role: Virtual Switch Active
Peer switch number           : 2
Peer switch operational role : Virtual Switch Standby
CORE-HCUA#
CORE-HCUA#show switch virtual link
VSL Status : UP
VSL Uptime : 3 days, 18 hours, 54 minutes
VSL SCP Ping : Pass
VSL ICC Ping : Pass
VSL Control Link : Te1/5/5
VSL Encryption : Configured Mode - Off, Operational Mode - Off
CORE-HCUA#
CORE-HCUA#show switch virtual role
RRP information for Instance 1
Valid  Flags   Peer      Preferred  Reserved
               Count     Peer       Peer
TRUE    V        1           1          1
Switch  Switch   Status      Priority     Role     Local   Remote
        Number               Oper(Conf)            SID     SID
LOCAL   1         UP         200(200)     ACTIVE    0       0
REMOTE  2         UP         100(100)     STANDBY   602     2042
Peer 0 represents the local switch
Flags : V - Valid
In dual-active recovery mode: No
CORE-HCUA#
Attachment with logg.
Reza Sharifi
According to the output of show commands you posted, the VSL link and overall VSS seems to be ok.
What is the issue?
I lost all service in 6500. Please see attached log.
There are a lot of hardware and software error messages n the log.  Open a case with TAC.  They maybe able to find a resolution for this.
Thanks. I have a question... what is this?
Aug 31 16:46:24 CL: %SYS-SW2-2-NULLCHUNK: Memory requested from Null Chunk -Process= "RF Slave Main Thread", ipl= 0, pid= 17
-Traceback= 70D4C3Cz 88D41CCz 88D6528z 5F1F730z 5F1FA28z 5F22E8Cz 6B86E00z 6B871B0z 6B87454z 6B88678z 6B8877Cz 71BEB18z 71BEC18z 71C0A34z 6B88B54z 6B88BA8z
Regards!
