Problem while configuring Port Security
itlogical
Having problem while configuring Port Security on Cat6509 with IOS Ver.12.2(18)sxf, Each fastEth port is configured with data and voice vlan.
The port security is not working on fastether ports my configs are in this way
sh run int fa1/46
Building configuration...
Current configuration : 351 bytes
interface FastEthernet1/46
switchport
switchport access vlan 10
switchport mode access
switchport voice vlan 20
switchport port-security maximum 3
switchport port-security violation restrict
switchport port-security mac-address xxxx.xxxx.xxxx
switchport port-security mac-address yyyy.yyyy.yyyy
no ip address
spanning-tree portfast
end
And following is the output of port security command verification
sh port-security
Secure Port MaxSecureAddr CurrentAddr SecurityViolation Security Action
(Count) (Count) (Count)
Total Addresses in System (excluding one mac per port) : 1
Max Addresses limit in System (excluding one mac per port) : 4096
sh port-security address
Secure Mac Address Table
Vlan Mac Address Type Ports Remaining Age
(mins)
10 xxxx.xxxx.xxxx SecureConfigured Fa1/46 -
10 yyyy.yyyy.yyyy SecureConfigured Fa1/46 -
10 zzzz.zzzz.zzzz SecureConfigured Fa2/6 -
And moreover the command #show port-security int fa1/46 shows nothing.I presume the port security configs are not applied for some unknown reasons.
If anybody come across or done such configs kindly let me know.your guidance will be of great help to me.
Best Regards
mbroberson1
Level 3
Level 3
You need to enable port-secuity on the port with the generic command "switchport port-security"
HTH,
Brandon
mbroberson1
Level 3
Level 3
HTH,
Brandon
Hello Mr.Brandon,
Thanks for your valuable suggestion the problem has been fixed by just configuring "switchport port-security" on the interface.
Kind Regards,
