Problem with 5760 WLC Management Port
bradquestion
I'm almost embarassed to ask this, but I seem to have an issue enabling the management port on a 5760 WLC -- two of them in fact.
On one unit I used the built-in setup script, on the other unit I tried manual configuring.
In both cases, the MGMT LED does not light up at all (I don't know what normal behavior is). Only when I set both the WLC and switch port (Cisco 4500) to auto does the switch show connected (at 100/HD) but the WLC shows down-down regardless of what I've tried.
Please tell me I'm missing something tremendously stupid here (and preferably what it is I'm missing).
Rasika Nayanajith
Below should help you on this
http://mrncciew.com/2013/12/12/getting-started-with-5760/
Rasika
**** Pls rate all useful responses ****
