Problem with access after add a catalyst 9200 to Meraki Dashboard
P4n0r4m1x
Hello;
After onboard a switch in the meraki cloud We lost the access via ssh TACACS, the switch allowed me to access but the first thing to show is % Authorization failed., if I disabled TACACS I can join in with a local password and work with normally.
I think that the issue is in the vty lines configuration, It´s now looks like:
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
privilege level 15
authorization commands 0 AAA
authorization commands 1 AAA
authorization commands 15 AAA
logging synchronous
login authentication AAA
length 0
transport input ssh
line vty 5 15
privilege level 15
transport input ssh
line vty 16 19
access-class MERAKI_VTY_IN in
access-class MERAKI_VTY_OUT out
authorization exec MERAKI
login authentication MERAKI
rotary 50
transport input ssh
The last block was added by meraki's onboarding script, and I think there we made the mistake. But I'm not sure how to fix it.
I could "default line vty 16 19 " but what configuration should it have? Another line vty 5 15 ??
The aaa config:
sh ru | section aaa
aaa new-model
aaa group server tacacs+ NAC_GROUP
server name NAC1
server name NAC2
aaa authentication attempts login 10
aaa authentication login default local
aaa authentication login AAA group NAC_GROUP local
aaa authentication login MERAKI local
aaa authentication enable default group NAC_GROUP enable
aaa authorization config-commands
aaa authorization exec default local
aaa authorization exec AAA group NAC_GROUP local
aaa authorization exec MERAKI local
aaa authorization commands 0 AAA group NAC_GROUP local
aaa authorization commands 1 AAA group NAC_GROUP local
aaa authorization commands 15 AAA group NAC_GROUP local
aaa accounting exec default start-stop group NAC_GROUP
aaa accounting commands 1 default start-stop group NAC_GROUP
aaa accounting commands 15 default start-stop group NAC_GROUP
aaa session-id common
And the tacacs+:
sh ru | section tacac
server name NAC1
server name NAC2
ip tacacs source-interface Vlan100
tacacs-server directed-request
tacacs server NAC1
address ipv4 101.101.101.1
key 7 0000000000000000000
tacacs server NAC2
address ipv4 101.101.101.2
Thanks in advance.
P4n0r4m1x
Hi guys:
After a couple reviews now It´s working... And the configs are :
server name NAC01
server name NAC02
tacacs server NAC01
address ipv4 10.101.101.1
key 7 **********
tacacs server NAC02
address ipv4 10.101.101.2
key 7 ************
AAA:
aaa new-model
server name NAC01
server name NAC02
aaa authorization console
Lines:
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
privilege level 15
logging synchronous
length 0
transport input ssh
line vty 5 15
privilege level 15
transport input ssh
line vty 16 19
rotary 50
transport input ssh
I hope it´s help !!!
Thanks a lot !!!
15 Replies 15
where the config ot TACACS ? I only see VTY.
P4n0r4m1x
Hi;
I just edited the post.
BR.
server name 101.101.101.1 <<- server name meaning server name resolve by dns, instead add server 101.101.101.1 directly
server name 101.101.101.2 <<- server name meaning server name resolve by dns, instead add server 101.101.101.2 directly
tacacs server 101.101.101.1
tacacs server 101.101.101.2
P4n0r4m1x
Ok but this is not issue, because I can login, so the dns is resolved, but when Im logged the first thing thats it's show to me is the
It's the same when you are config tacacs with a local account then you active the tacacs in ISE and any command you executed shows
Thanks in advance.
you config auth via tacacs and local, so there is chance that you auth using local not tacacs if you use local username/password same as tacasc username/password
change the server name to server and check again.
The username and password are totally different and can’t be equals, anyway I need to use tacacs because it’s a production device and if something happens to have evidences who was, what done…
please can you check this config
line vty 25 30
transport input telnet
rotary 75 <<- use 3075 with telnet to access to this VTY group.
P4n0r4m1x
Thanks mate;
I did try with this config and it´s the same behavior over port 23. It let me log in but i cant do anything with TACACs activated.
Username:
Password:
just try telnet not SSH and I mention we use rotary 75 so you need
telnet <SW IP> port 3075
try this and share result
P4n0r4m1x
Same behavior, over port 22, 23 and 3075:
Username:
Password:
% Authorization failed.    <--- Notice that isnt % Authentication failed (wrong password)
I know that it is authz not auth issue
line vty 25 30
authorization exec default  <<- remove this and try again using telnet port 3075
P4n0r4m1x
This line is not in my conf, and I added again but it not appear
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
privilege level 15
logging synchronous
length 0
transport input ssh
line vty 5 15
privilege level 15
transport input ssh
line vty 16 19
rotary 50
transport input ssh
line vty 20 24
transport input ssh
line vty 25 30
rotary 75
Also in the NAC I can see Passed-Authentication: Authentication succeeded
but then nothing.
BR.
Hello
Your AAA seems to be quite convoluted , it seems you are trying to allow access to different vty line using various AAA profiles.
The below example should work which you could amend to accommodate your requirements.
username stan privilege 15 algorithm-type scrypt secret xxxxx
tacacs server NAC1
address ipv4 x.x.x.x
key xxxx
timeout 5
tacacs server NAC2
address ipv4  y.y.y.y
key xxxxx
timeout 5
aaa new-model
aaa group server tacacs+ MERAKI
server name NAC1
server name NAC2
aaa authorization exec MERAKI local if-authenticated
line vty 0 4
Kind Regards
Paul
P4n0r4m1x
Hello;
Thanks for your time and help but It doesn't work in this way, because my TACACS groups has another name ... But i tried changed it and doesn't work either..
We need to can work on it a local users, tacacs users from NAC_GROUP and the MERAKI one for monitoring in meraki's dashboard. But in this way I only can work with local users and with tacacs disabled coz the hasn't permits.
This is the config that I'm running right now:
tacacs server NAC01
key ******
tacacs server NAC02
key ******
aaa new-model
server name NAC01
server name NAC02
aaa authentication enable default group NAC_GROUP enable group MERAKI
And how a told you still disabling TACACS for make it workiing ... also meraki dashboard lost the telemetry
Thanks in advance
