problem with ASR 1001 licence IPSEC
lotfi.bouhaddad
I have a problem with a licence for ASR 1001 router, We buy for our client 2 licence in order to have IPSEC VPN configured on the ASR, The licences are : advipservices and IPSEC.
After installing the licences on the box, the show licence give us this output:
MLV-CIS-Internet-1#show license
License Store: Primary License Storage
StoreIndex:  0  Feature: ipbase                            Version: 1.0
        License Type: Permanent
        License State: Active, Not in Use
        License Count: Non-Counted
        License Priority: Medium
StoreIndex:  1  Feature: advipservices                     Version: 1.0
        License State: Active, In Use
StoreIndex:  2  Feature: ipsec                             Version: 1.0
it looks like the IPSEC licence is not in use even after showing "successful installed license"
Please help.
Hers is the show version of the box and the show license feature:
MLV-CIS-Internet-1#show version
Cisco IOS Software, IOS-XE Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.1(3)S6, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 09-Sep-13 10:37 by mcpre
MLV-CIS-Internet-1 uptime is 4 weeks, 1 day, 19 hours, 25 minutes
Uptime for this control processor is 4 weeks, 1 day, 19 hours, 26 minutes
System returned to ROM by reload
System image file is "bootflash:/asr1001-universalk9.03.04.06.S.151-3.S6.bin"
Last reload reason: Reload Command
MLV-CIS-Internet-1#  show license feature
Feature name        Enforcement   Evaluation  Clear Allowed  Enabled
adventerprise                           yes           no          yes            no
advipservices                           yes           no          yes            yes
ipbase                                       no            no          yes            no
throughput                              yes           no          yes            no
internal_service                        yes           no          yes            no
sw_redundancy                           yes           no          yes            no
ipsec                                        yes           no          yes            no
Lotfi
Reza Sharifi
have you actually try to create and IPsec tunnel and see if it works?
If not, you can also use the "clear license" command and reinstall it again.
I can't test IPSEC tunnel without being sure that the license is working as we need to make down the system just one time.
The clear of license donsn't wotk...
What I need to know, is if I really need the IPSEC license in order to have tunnel UP or is it just an optionnal one ?
Lotfi
