problem with Cisco 3560 switch
rajib_das
I have using Cisco 3560 catalyst switch
with IOS Release 12.2(25)SEB4. But the problem is that the switch does not support
service-policy output to restrict egress bandwidth in an interface as we can do in Cisco 3550 switch.
Any workout in this problem.....
Rajib
royalblues
Level 10
Level 10
Rajib,
3560 does not support egress policing. It supports policing on the ingress
try the command service-policy input < >
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3560/12225se/3560scg/swqos.htm#wp1044737
HTH, rate if it does
Narayan
slaptijack
To get the egress policing you need, without buying new hardware, you might trying using a class-map to match the traffic and a policy-map to apply traffic-shaping.
Apply the policy-map to your router interface with the service-policy command.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800bd909.html
