Problem with creating a VLAN on 2800
mvilla
Good morning:
I have a problem to create a VLAN with a Cisco 2801.
I need to have base ports FastEthernet 0 / 0 and FastEthernet 0 / 1, in the same VLAN.
Basically I'm trying to switch access redundacion, now I have redundant switches in which I have the servers, but if one of these switches fails, and coincidentally is where I have connected the router, the server runs out of internet connection.
I idea is to connect the FastEthernet 0 / 0 to a switch, and FastEthernet 0 / 1, to the other switch.
but I managed to have these two ports in the same vlan, in order to have a unique IP for both FastEthernet ports.
As I can do this?. do is a lot of documents using the switchport command, but this command is not available in my router, I tried different IOS, and nothing.
Currently I have the following IOS: c2801-adventerprisek9-mz.124-24.T6.bin
thank you very much for your help.
You can use IRB & a BVI
bridge irb
bridge 111 protocol ieee
bridge 111 priority 65535
bridge 111 route ip
interface BVI111
description *** VOICE VLAN 111 ***
ip address 172.16.16.1 255.255.255.0
int g0/0
description *** TEST VGWAY PRIMARY CONNECTION TO SWITCH TEST-1-G1/0/2 ***
no ip address
bridge-group 111
int g0/1
description *** TEST VGWAY SECONDARY CONNECTION TO SWITCH TEST-1-G1/0/2 ***
no ip address
bridge-group 111
Alex
Please rate useful posts
Regards, Alex. Please rate useful posts.
Reza Sharifi
Hi Martin,
You can not put both interfaces in the same subnet.  These ports are routed ports and need to be in a separate IP segments.  The router does not support vlan, however it does support 802.1Q with sub-interfaces.
bridge irb
bridge 111 route ip
interface BVI111
int g0/0
no ip address
bridge-group 111
int g0/1
no ip address
bridge-group 111
Alex
