Problem with DHCP server and VLAN (Cisco 876)
martin.grugel
i use a Cisco 876 as an internet gateway over broadband (Telekom DSL in germany). I think i did sth wrong with the dhcp-configuration. I only want to use the dhcp-server of the Cisco 876 for VLAN3 (guest VLAN with wireless access point Aironet LAP1142N). The other VLANs get their IPs from an Windows Server 2012 which works well. But when i connect a wireless device or directly with ethernet cable the device won't get any IP in the 192.168.14.0 subnet. When I set the IP manually (for ex. 192.168.14.123 and 192.168.14.1 als gw and dns) i can connect to the internet without problems. This tells me, that there is no problem with the VLAN config but perhaps a misconfigured DHCP-server on the Cisco 876.
Here's my config:
! Last configuration change at 14:10:01 UTC Thu Nov 18 2010 by root
version 15.1
no service pad
hostname cisco876-adh11
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
dot11 syslog
ip source-route
ip dhcp excluded-address 192.168.14.1 192.168.14.19
ip dhcp excluded-address 192.168.14.150 192.168.14.254
ip dhcp excluded-address 192.168.12.0
ip dhcp excluded-address 192.168.13.0
ip dhcp pool DHCPGuestWLAN
network 192.168.14.0 255.255.255.0
default-router 192.168.14.1
dns-server 192.168.14.1
lease 3
ip cef
ip domain name adh11.local
ip name-server 194.25.2.129
no ipv6 cef
vpdn enable
vpdn-group 1
archive
log config
  hidekeys
username root privilege 15 secret 4 xxxxx
interface BRI0
no ip address
ip access-group 102 in
ip nat inside
ip virtual-reassembly in
encapsulation hdlc
ip tcp adjust-mss 1452
shutdown
interface ATM0
no ip address
no ip route-cache
no atm ilmi-keepalive
pvc 1/32
  pppoe-client dial-pool-number 1
interface FastEthernet0
switchport mode trunk
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
description ADH11 - Internes LAN
ip address 192.168.12.1 255.255.255.0
ip nat inside
interface Vlan2
description DMZ
ip address 192.168.13.1 255.255.255.0
ip access-group 120 in
ip nat inside
interface Vlan3
description Cisco-GuestWLAN
ip address 192.168.14.1 255.255.255.0
ip access-group 130 in
ip nat inside
interface Vlan4
description reserved4VOIP
ip address 192.168.15.1 255.255.255.0
interface Dialer1
description PPPoE Dialin T-Online
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname XXXXX
ppp chap password 0 XXXXX
ppp pap sent-username XXXXX password 0 XXXXX
ppp ipcp dns request accept
ppp ipcp route default
no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
ip dns server
ip nat inside source list 101 interface Dialer1 overload
ip nat inside source static tcp 192.168.12.234 22 interface Dialer1 22
ip nat inside source static tcp 192.168.12.211 80 interface Dialer1 80
ip nat inside source list 120 interface Dialer1 overload
ip nat inside source list 130 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1 permanent
access-list 101 permit ip 192.168.12.0 0.0.0.255 any
access-list 102 remark ### internes LAN (ADH11) ###
access-list 102 deny   ip 192.168.12.0 0.0.0.255 192.168.13.0 0.0.0.255
access-list 102 deny   ip 192.168.12.0 0.0.0.255 192.168.14.0 0.0.0.255
access-list 102 deny   udp any range netbios-ns netbios-ss any
access-list 102 deny   tcp any eq 139 any
access-list 102 permit ip any any
access-list 120 remark ### DMZ ###
access-list 120 deny   tcp 192.168.13.0 0.0.0.255 host 192.168.13.1 eq www
access-list 120 deny   tcp 192.168.13.0 0.0.0.255 host 192.168.13.1 eq 443
access-list 120 deny   tcp 192.168.13.0 0.0.0.255 host 192.168.13.1 eq 22
access-list 120 deny   ip 192.168.13.0 0.0.0.255 192.168.12.0 0.0.0.255
access-list 120 deny   ip 192.168.13.0 0.0.0.255 192.168.14.0 0.0.0.255
access-list 120 permit ip 192.168.13.0 0.0.0.255 any
access-list 130 deny   tcp 192.168.14.0 0.0.0.255 host 192.168.14.1 eq www
access-list 130 deny   tcp 192.168.14.0 0.0.0.255 host 192.168.14.1 eq 443
access-list 130 deny   tcp 192.168.14.0 0.0.0.255 host 192.168.14.1 eq 22
access-list 130 remark ### GuestWLAN ###
access-list 130 deny   ip 192.168.14.0 0.0.0.255 192.168.12.0 0.0.0.255
access-list 130 deny   ip 192.168.14.0 0.0.0.255 192.168.13.0 0.0.0.255
access-list 130 permit ip 192.168.14.0 0.0.0.255 any
no cdp run
control-plane
line con 0
privilege level 15
login local
no modem enable
line aux 0
privilege level 15
login local
line vty 0 4
access-class 1 in
privilege level 15
login local
transport preferred ssh
transport input ssh
scheduler max-task-time 5000
end
Thanks for any help.
Bye
Martin
cadet alain
ip access-list extended 130
10 permit udp any eq bootpc any eq bootps
Alain
cadet alain
Alain
Hey Alain,
thank you, you solved it!
Hi Martin,
Can you mark the thread as solved and rate the helpful answers accordingly.
Alain
