Problem with dhcp snooping database
svark13
Frequent Visitor
Frequent Visitor
Got a strange problem, maybe some of you could help.
Dhcp snooping is up and running, database are saved to tftp file, all looks good. Snooping running on one vlan,
switch#show ip dhcp snoo
Switch DHCP snooping is enabled
Switch DHCP gleaning is disabled
DHCP snooping is configured on following VLANs:
20
DHCP snooping is operational on following VLANs:
20
DHCP snooping is configured on the following L3 Interfaces:
Insertion of option 82 is enabled
circuit-id default format: vlan-mod-port
remote-id: 0056.3c9c.c800 (MAC)
Option 82 on untrusted port is allowed
Verification of hwaddr field is enabled
Verification of giaddr field is enabled
DHCP snooping trust/rate is configured on the following Interfaces:
Interface Trusted Allow option Rate limit (pps)
TenGigabitEthernet1/0/12 yes yes unlimited
Custom circuit-ids:
TenGigabitEthernet2/0/10 yes yes unlimited
Custom circuit-ids:
But, when trying to read binding database from file I got this error:
May 2 11:37:23.681: two gig ethernet port
May 2 11:37:23.681: DHCP_SNOOPING: number not found where expected in interface name
May 2 11:37:23.681: Token for interface not valid.
Im expeting to see either new binding entries or binding collisions. The file are populated with entries that the switch made itself.
I really not sure how to interpret the debug messages, do any of you have any tips?
sh ver,
Cisco IOS Software [Denali], Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 16.3.6, RELEASE SOFTWARE (fc3)
0 Replies 0
