problem with downloading a IOS
insert7992
I need to download the IOS 12.4(11)T. I went to :
http://www.cisco.com/public/sw-center/
and clicked on :
"Cisco IOS Software"
The authentication is always failed when I type in my CISCO account and password.
Why does this happen? I'm sure I didn't make mistakes on typing. Do I need to register another high level account(if it exist) to obtain the IOS?
Thanks in advance.
Joe
19 Replies 19
WCCP is just a redirector and most of the work is done by the web cache engine, in this case Squid.
I'm not familiar with Squid so I won't be able to give you any advise on that.
BTW, I reviewed the link you posted and I believe he is referring to this bug:
CSCuk54872
Bug Details
Headline
No WCCP/CEF support in C1700-ADVSECURITYK9-M image
Product
IOS
Feature
WCCP
Components Duplicate of
Severity 3 Severity help Status Resolved Status help
First Found-in Version 12.3 All affected versions First Fixed-in Version 12.3(12.5), 12.3(12.6)T, 12.3(11)T06, 12.3(8)T09, 12.3(11)YW Version help
Release Notes
Symptom:
Redirection by WCCP does not occur in the ADVSECURITYK9 image.
Conditions:
Both WCCP and CEF are enabled.
Workaround:
Redirection will work if CEF is disabled. However before this is done the performance implications
should be considered. An alternative is to use a different image variant for the platform if the
features of ADVSECURITYK9 are not required.
Thanks.
Do I need to warry about this WCCP/CEF bugs in the combination of 12.4(11)T and 2610XM? In addition, I'm not quite understand the bug details you showed me. Is it because of image object?(this could be a naive question)
No, you don't need to worry on 12.4(11)T and versions listed above such as:
Thank you for all your help. I really mean it. It will take for ever to set up my experiment system without your kindly help.
