problem with enable ssh (switch L3 ) 4500x
eddanilo2016
Frequent Visitor
Frequent Visitor
I currently have the version as mentioned below
SW-CORE-4500-X#show version
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSAL-M), Version 03.03.02.SG RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 24-Oct-12 00:32 by prod_rel_team
ROM: 15.0(1r)SG10
SW-CORE-4500-X uptime is 7 weeks, 1 day, 15 hours, 43 minutes
System returned to ROM by reload
Running default software
Jawa Revision 2, Winter Revision 0x0.0x40
Last reload reason: Reload command
License Information for 'WS-C4500X-16'
License Level: ipbase Type: Permanent
Next reboot license Level: ipbase
cisco WS-C4500X-16 (MPC8572) processor (revision 9) with 4194304K/20480K bytes of memory.
Processor board ID JAE181200NA
MPC8572 CPU at 1.5GHz, Cisco Catalyst 4500X
Last reset from Reload
20 Virtual Ethernet interfaces
16 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
16162 -rw- 112660260 Apr 7 2014 03:22:49 -05:00 cat4500e-universal.SPA.03.03.02.SG.151-1.SG2.bin
when I tried to enable ssh con el line vty does not appear
option
SW-CORE-4500-X(config-line)#transport in
SW-CORE-4500-X(config-line)#transport input ?
all All protocols
none No protocols
telnet TCP/IP Telnet protocol
willwetherman
You will need the k9 Crypto image to support SSH.
cat4500e-universalk9.SPA.03.03.02.SG.151-1.SG2.bin
Mark Malone
that's not a K9 image that supports crypto you would need this instead below with K9
I would though if upgrading for crypto move to this instead , recommended image
cat4500e-universalk9.SPA.03.06.06.E.152-2.E6.bin
Hi Mark,
Thanks for your answer.
I have upgraded to cat4500es8-universalk9.SPA.03.06.04.E.152-2.E4.bin but after reloading SW, module 1 and 10 was showing "unsupported module" status. Then we reverted back to iOS : cat4500es8-universal.SPA.03.08.04.E.152-4.E4.bin which was came with Switch by-default. Now both modules are up still we are not able to ssh the SW.
Please suggest.
