Problem with Etherchannel cross-stack
cisco_tno
Community Member
Hi there,
I am having problems with and etherchannel between 2 stacks of Catalyst 3750X. It was working for several weeks but now, one interface is down.
I have 2 3750X in stack at site A, and 2 3750X in stack at site B. They are connected through fiber in cross-stack way. This is:
1/1/4 ---> 2/1/4
2/1/4 ---> 1/1/4
We are using 100FX SFPs because of distance between Site A and Site B (more than 550m).
Some weeks ago, we configured the etherchannel and everything was working perfectly.
The configuration is:
SITE A
interface GigabitEthernet1/1/4
switchport trunk allowed vlan 100
switchport mode trunk
duplex full
channel-group 1 mode active
end
interface GigabitEthernet2/1/4
duplex full
end
interface Port-channel1
description AGREGACION->SWIPOCCIS01
duplex full
end
Group  Port-channel  Protocol    Ports
1      Po1(SU)         LACP      Gi1/1/4(I)  Gi2/1/4(P)
SITE B
duplex full
end
duplex full
end
duplex full
end
1      Po1(SU)         LACP      Gi1/1/4(P)  Gi2/1/4(D)
As you can see, at site A the interface 1/1/4 is marked as "I", and at site B the interface 2/1/4 is marked as "D".
The weird thing here is that at site A the LED of 1/1/4 is GREEN, and the LED for 2/1/4 at site B is OFF. Very weird thing ...
Any ideas?
Thank you very much.
Reza Sharifi
couple of things you can try
do a sh and no sh under interface 2/1/4
if this does not help, unplugs 2/1/4 physically and than plug it back in.
If not you may have a bad SFP.
Also, is there way for you to test the fiber?  You may have a bad patch.
