How does TACACS+ host order of operations
V120311
        I am trying to find out how does TACACS+ work? I know that one can configure multiple TACACS+ servers. However, whenever I enter a command into the switch is the switch sending each command line to the TACACS+ server for "Authorization"?
Thank you,
Victor
turnera
Victor,
TACACS+ is only used when you area accessing, or loging onto, a device. Once you authenticate your credentials to a TACACS server, you are then just working within the confines of the device you have logged onto. You do not authenticate any configuration commands to the TACACS server as you are working on that device.
It is just for AAA and not for configuring a device.
Turnera,
So the "AAA Authorization" parameter is just used during login time to "Authorize" which commands are allowed after one has logged in?
If you have designated specific levels of access with the AAA Authorization configuration, once an individual logs in, that level of authorization is then associated with the user. Then that user is restricted throughout the session to the level of access authorized by the AAA authorization configuration.
aaa authorization {network | exec | commands level | reverse-access | configuration} {defaultlist-name} method1 [method2...]
If you use this command and then set a command level, that user will only have the command access associated with that particular level.
