Problem with EVENT
kudachkin
Community Member
Hi everybody.
Early - i use
event manager applet APPLET1
event track 1 state any
action ACTION1 cli command "enable"
action ACTION4 cli command "clear ip nat translation *"
To clear nat translation when one link to ISP fall and i reconnect to another
But now  in 12.4(19b) - ADVSECURITY - i can use *event track 1 state any* - becose IOS doesn't know this.
What can i do? Maybe somebody knew?
Joe Clarke
Enhanced Object Tracking support was not added to EEM until 12.4(2)T.  In the meantime, you can use the syslog ED to do what you want.  For example:
event manager applet track-down
event syslog pattern "TRACKING-5-STATE: 1.*Up->Down"
action 1.0 cli command "enable"
action 2.0 cli command "clear ip nat translation *"
If the syslog message is not available, then you can use SNMP and the CISCO-RTTMON-MIB.  Here is an example:
https://supportforums.cisco.com/docs/DOC-8069
Joe Clarke
Great! That's work right.
Thanks a lot!
