Problem with givin internet access to users using cisco 871 router
icefisherman
I'm currently undergoing CCNa academy so I got a "job" from  my boss to configure Cisco 871 router.  Unfortunately we just finished  first semester at academy so there are some things that I'm still having  hard time to understand.
I managed to configure router so it connect to internet or to be  exact it has internet access through  another adsl modem that is in  bridge mode.
Here is picture of setup
http://www.pohrani.com/f/3m/EI/gxiOrOu/network.jpg
The problem is that users are not able to use internet when connected  to this router.  I'm able to access router through telnet  ( ip  192.168.13.10)  but that's it.
Here is the config from router  http://pastebin.com/8JaMmqdT
192.168.13.0 255.255.255.128 is network that we use at work.   192.168.13.5 is IP address that is assigned to zyxel adsl modem ( If I'm  correct, we could have used any address here since we are connecting  this directly to router ? )
Zyxel adsl modem  is connected to FA4 port on Cisco router.   LAN  cable is connected to FA0 port and from there it goes to switch ( it's  some  asus switch with 50 ports).
Here is routing table
Router-Cisco#show ip route Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP        D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area        N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2        E1 - OSPF external type 1, E2 - OSPF external type 2        i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2        ia - IS-IS inter area, * - candidate default, U - per-user static route        o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.13.5 to network 0.0.0.0
          192.168.13.0/24 is variably subnetted, 2 subnets, 2 masks
  S       192.168.13.5/32 is directly connected, Dialer1
  C       192.168.13.0/25 is directly connected, Vlan1
          172.29.0.0/32 is subnetted, 1 subnets
  C       172.29.252.89 is directly connected, Dialer1
          93.0.0.0/32 is subnetted, 1 subnets
  C       93.139.143.80 is directly connected, Dialer1
          10.0.0.0/24 is subnetted, 1 subnets
  C       10.10.10.0 is directly connected, Loopback0
  S*      0.0.0.0/0 [1/0] via 192.168.13.5
And here is IP interface brief
Router-Cisco#show ip interface brief Interface                  IP-Address      OK? Method Status                Protocol Dialer0                    unassigned      YES manual administratively down down
Dialer1                    93.139.143.80   YES IPCP   up                    up
FastEthernet0              unassigned      YES unset  up                    up
FastEthernet1              unassigned      YES unset  administratively down down
FastEthernet2              unassigned      YES unset  administratively down down
FastEthernet3              unassigned      YES unset  administratively down down
FastEthernet4              unassigned      YES manual up                    up
Loopback0                  10.10.10.100    YES manual up                    up
Virtual-Access1            unassigned      YES unset  up                    up
Vlan1                      192.168.13.10   YES manual up                    up
If I ping google dns from router e.g. ping 8.8.8.8 it works.  If I ping www.google.com it doesn't work.
Also I'm able to access router via 192.168.13.10 but if I use router as  default gateway then I'm not able to access the internet.
Can anyone point me in right direction here or tell me what I missed out ?
p.s.  From where is network   172.29.0.0/32 is subnetted, 1 subnets       C       172.29.252.89 is directly connected, Dialer1 comming from ?  I cleared router config before starting and I don't  remember configuring this one or that we use something like this at  work.
p.p.s
One more thing  that is bugging my head.  If I  understand correctly, I can have more vlan's using same port ?  E.g. that I have vlan 1 to 5 using FA0 port ?
I'm asking this because we have 3 more  internet connections/adsl modems. So I'm interested if  I could use remaining 3 LAN ports on router ( Fa1 to 3) and connect each of them to one of the adsl modems that are in bridge mode. Then I would assign each of this "internet" connections to one of the vlans.   E.g. vlan1( on FA0) would use FA4 which is connected to adsl modem in bridge mode, vlan2(FA0) would use FA3 which is connected to ads modem in bridge mode and so on.
Is something like this possible ?
2 Accepted Solutions
ErickBCCNA
Hi.
It looks like you enabled NAT on the interfaces, but you don't actually have any NAT configuration on your router?
access-list 1 permit 192.168.113.0 0.0.0.127
ip nat inside source list 1 interface dialer1 overload
There may be other things missing, but that's what I saw what I took a brief look at your configuration.
cadet alain
you got an incorrect default-gateway in your dhcp pool, it should be the interface vlan 1 Which is your nat inside interface.
default-router 192.168.13.5 -----> change to 192.168.13.10
also do NAT overload on dialer1  interface: ip nat inside source list 1 interface dialer 1
if you want to ping google.com from the router:
ip domain-lookup
ip name-server  8.8.8.8
no ip name-server 192.168.13.3
no ip name-server 195.29.150.3
if the zyxel is in bridged mode then why have a static route to it as it is not routing anymore.
change your default route to point to dialer1 interface
Alain
8 Replies 8
ErickBCCNA
Hi.
cadet alain
ip domain-lookup
Alain
It's working now. thank you.
But  internet connection is very slow. It measuers   around 0.38Mbps and it should be around 20Mbit/s
Googling didn't gave me any lead regarding this so could you tell me what and where to look ?
thank you
could you issue a Show Interface and post the output?
Plus, how many nat translations are there in use?
Could you also post
Show ip nat statistics?
icefisherman
Here is show interface
Dialer1 is up, line protocol is up (spoofing)
  Hardware is Unknown
  Description: ADSL WAN dialer
  Internet address is 93.139.219.92/32
  MTU 1492 bytes, BW 20480 Kbit, DLY 20000 usec,
  Encapsulation PPP, loopback not set
  Keepalive set (10 sec)
  DTR is pulsed for 1 seconds on reset
  Interface is bound to Vi1
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 1d05h
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/0/16 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 15360 kilobits/sec
     24887 packets input, 13155487 bytes
     24198 packets output, 4015667 bytes
Bound to:
Virtual-Access1 is up, line protocol is up
  Hardware is Virtual Access interface
  MTU 1492 bytes, BW 56 Kbit, DLY 20000 usec,
  Encapsulation PPP, LCP Open
  Open: IPCP
  PPPoE vaccess, cloned from Dialer1
  Vaccess status 0x44, loopback not set
  Interface is bound to Di1 (Encapsulation PPP)
  Last input 00:02:18, output never, output hang never
  Last clearing of "show interface" counters 02:41:22
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     16135 packets input, 12913614 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     15518 packets output, 3661938 bytes, 0 underruns
     0 carrier transitions
FastEthernet0 is up, line protocol is up
  Hardware is Fast Ethernet, address is 0016.c78e.5cf3 (bia 0016.c78e.5cf3)
  Description: LAN izlaz
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Full-duplex, 100Mb/s
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 3
  5 minute input rate 5000 bits/sec, 5 packets/sec
  5 minute output rate 1000 bits/sec, 1 packets/sec
     479715 packets input, 44165054 bytes, 0 no buffer
     Received 409065 broadcasts, 0 runts, 0 giants, 0 throttles
     78393 packets output, 17893837 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
     0 lost carrier, 0 no carrier
FastEthernet1 is administratively down, line protocol is down
  Hardware is Fast Ethernet, address is 0016.c78e.5cf4 (bia 0016.c78e.5cf4)
  Auto-duplex, Auto-speed
     0 packets input, 0 bytes, 0 no buffer
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
FastEthernet2 is administratively down, line protocol is down
  Hardware is Fast Ethernet, address is 0016.c78e.5cf5 (bia 0016.c78e.5cf5)
FastEthernet3 is administratively down, line protocol is down
  Hardware is Fast Ethernet, address is 0016.c78e.5cf6 (bia 0016.c78e.5cf6)
FastEthernet4 is up, line protocol is up
  Hardware is PQUICC_FEC, address is 0016.c78e.5cfd (bia 0016.c78e.5cfd)
  Description: WAN veza - Cisco-router  <-> zyxel
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 02:41:02, output 00:00:04, output hang never
  Input queue: 0/75/15/0 (size/max/drops/flushes); Total output drops: 0
     31533 packets input, 13984553 bytes
     Received 0 broadcasts, 0 runts, 0 giants, 13 throttles
     15 input errors, 0 CRC, 0 frame, 0 overrun, 15 ignored
     0 watchdog
     28623 packets output, 4932451 bytes, 0 underruns
     0 output errors, 0 collisions, 4 interface resets
Loopback0 is up, line protocol is up
  Hardware is Loopback
  Description: Loopback interface
  Internet address is 10.10.10.100/24
  MTU 1514 bytes, BW 8000000 Kbit, DLY 5000 usec,
  Encapsulation LOOPBACK, loopback not set
  Last input 1d02h, output never, output hang never
  Output queue: 0/0 (size/max)
     9 packets output, 516 bytes, 0 underruns
  Open: IPCP
  Last input 00:02:20, output never, output hang never
  Last clearing of "show interface" counters 02:41:23
Vlan1 is up, line protocol is up
  Hardware is EtherSVI, address is 0016.c78e.5cf3 (bia 0016.c78e.5cf3)
  Internet address is 192.168.13.10/25
  MTU 1500 bytes, BW 100000 Kbit, DLY 1000000 usec,
  Last input 00:00:00, output never, output hang never
  Input queue: 1/75/0/0 (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 4000 bits/sec, 5 packets/sec
  5 minute output rate 1000 bits/sec, 2 packets/sec
     463284 packets input, 39651545 bytes, 103 no buffer
     Received 431213 broadcasts, 0 runts, 0 giants, 0 throttles
     31344 packets output, 14228416 bytes, 0 underruns
     0 output errors, 1 interface resets
I tried setting bandwith for dialer1 but it didn't help.
show ip nat statistic
Total active translations: 67 (0 static, 67 dynamic; 67 extended)
Outside interfaces:
  Dialer1, Virtual-Access1
Inside interfaces:
  Vlan1
Hits: 28993  Misses: 858
CEF Translated packets: 29450, CEF Punted packets: 370
Expired translations: 943
Dynamic mappings:
-- Inside Source
[Id: 3] access-list 1 interface Dialer1 refcount 0
[Id: 1] access-list 10 interface Dialer1 refcount 67
Queued Packets: 0
As for nat translations. Don't know if this is what you asked for but I did show ip nat translations and this is what I get
http://pastebin.com/rEZ6G4TT
int vlan 1
ip tcp adjust-mss 1452
ip mtu 1492
Regards.
Alain
icefisherman
Now it got to 0.66 Mbps but that is still not even close to real speed.
Reloading configuration helped. It's working at full speed now. Should have tried that right away
