Problem with HSRP
albertog
Community Member
I have three switches conected A-B-C, the switch A is connect to one router, and the switch C is connect to the other router.The two routers are configured for HSRP for this lan and them have one wan connection between them. When the links between A-B or B-C is down the two routers are active for HSRP, and it give me for the routing. How can I configure the HSRP for that one of the routers put is standby when the link is down??.
Best regards and thanks...
keduncan
Level 2
Level 2
I do not know of a way to accomplish what you want. I suggest that you do etherchannels with multiple ports between the switchs so, If you loose one port the routers will still talk and both wont go into active with a single failure.
