3750: High CPU Utilization...Causes?
w-sims
Community Member
I have a 2 switch stack of 3750-12S That have High CPU utilization primarily with the IP Input process. Any suggestions as to causes?
8 Replies 8
royalblues
Level 11
Level 11
can you please post the output of show version and sh processes CPU.
Narayan
Attached is the requested info.
pjosefson
Community Member
Did you ever resolve this? I have a customer with similar problems, and I *think* I've narrowed it down to worm-infected clients trying to infect random addresses (leading to LOTS of new flows having to be routed by the CPU).
That would certainly do it if you have infected clients . If this is the case I would find out why the antivirus isn't working on their machines .
As I would... unless they were CaTV broadband customers - I have no desire to instill into them the notion that I am available around the clock for support... or take any responsibility whatsoever for their antivirus solutions... 🙂
Waving with my customer's AUP might do the trick, though, but as their staff is 1.5 people, I don't think they care much for spending time waving...
However... I DO suspect a middlebox (NetIntact PacketLogic) is doing some sending of gratuitous RST:s... meaning that even updated Windows machines maximum-connection-per-host is thwarted. I so do NOT like middleboxes (esp. since I didn't sell it in the first place)...
/Peter
w-sims
Community Member
Is your client switch/routing Tivoli Service Manager (TSM) across this switch?
pjosefson
Community Member
Not that he knows of. Broadband customers - individuals/households as well as commercial (problems most severe at night, when the commercial customers don't do much, so it shouldn't be them). But you tickled my curiousity. Why?
More info: The network is a mini-MAN in a town with almost exactly 10000 residents. The 3750 cluster is the core L3 equipment, access layer is L2 switches.
We MAY be oversubscribing the TCAM, as we have almost a hundred VLAN:s running L3 (as opposed to the 8 in the example in the sdm template). On the other hand, 100 / 8 = 12.5 and we are nowhere near 12.5 times the numbers supported by the template. We more or less only have a default gateway (upstream ISP) and then each directly connected VLAN.
Also, I feel I would see interrupt load then (as CEF in CPU would show as CPU load), not IP Input. Right?
/Peter
