Problem with Internet in Second VLAN (Cisco 877W)
andonisvoug
I am having problems getting my second Vlan (VLAN2) to have internet as the first one (VLAN1).  I setup two Vlans:
Vlan1  IP's 10.10.10.1-254  "SSID Cisco", this one works fine and works over wireless and wired clients.
Vlan2  IP's 192.168.1.1-254 "SSID Andonis", i gave this one DNS from OPENDNS (familyshield to be able to block bad sites for my kids) and its giving away the IP's just                                            fine but there is no internet.
What do you think i am doing wrong?
Here is my config:
version 12.4
no service pad
hostname **********
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
crypto pki trustpoint TP-self-signed-2990631934
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2990631934
revocation-check none
rsakeypair TP-self-signed-2990631934
crypto pki certificate chain TP-self-signed-2990631934
certificate self-signed 01
  3082024F 308201B8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32393930 36333139 3334301E 170D3032 30333036 31383231
  31345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 39393036
  33313933 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100CF07 6A309C0C 4B515D27 80F794F7 5C94C05F 1968DA5F A9286BFF D0090DD0
  8CE3CB05 90F2091E FAF5AEA3 A215E095 94BC1CF9 25F79DC2 F2682FBD D22B1934
  B9B230F8 42A5F460 178BA4C2 C94188A0 5111E3FB E39CA9B6 1D3C2415 3EE19AB2
  E0655341 B03E4B19 205F47F0 B23FC3D4 D20097FE 76B2D9CF 99912446 E0B6A79A
  B83B0203 010001A3 77307530 0F060355 1D130101 FF040530 030101FF 30220603
  551D1104 1B301982 17796F75 726E616D 652E796F 7572646F 6D61696E 2E636F6D
  301F0603 551D2304 18301680 146BD667 6566BFB9 5B6ED3FE 7FCCC66E 84A3D8E6
  77301D06 03551D0E 04160414 6BD66765 66BFB95B 6ED3FE7F CCC66E84 A3D8E677
  300D0609 2A864886 F70D0101 04050003 81810090 ED81DE0E 0CD42EBC 1DF3C08E
  BEC4C55B FB617092 C6A61C20 B2B46CB3 0719660B A776E879 02D903D7 BB9483CB
  72DC966E 1A293038 C0FA6D1D BBEDCA48 A422774F CE233657 2FDD452A 0F076814
  606C3820 284F226A 3895FD0D E49E10E8 3FD6F443 6685408E B06188DA DDE4BFC1
  FB307732 5872DA81 F1B61A8F C8DAE0E0 D06821
      quit
dot11 syslog
dot11 ssid cisco
   vlan 1
   authentication open
   mbssid guest-mode
ip cef
no ip dhcp use vrf connected
ip dhcp pool ccp-pool
   import all
   network 10.10.10.0 255.255.255.0
   default-router 10.10.10.1
   dns-server 62.169.194.17 62.169.194.18
   lease 0 2
no ip domain lookup
ip domain name ********!
username ********* privilege 15 secret 5 **********************
archive
log config
  hidekeys
bridge irb
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 8/35
  pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
encryption vlan 1 key 1 size 40bit 0 *********** transmit-key
encryption vlan 1 mode wep mandatory
broadcast-key vlan 1 change 30
ssid cisco
mbssid
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname *****************
ppp chap password 0 ***********
ppp pap sent-username ********** password 0 *********
interface BVI1
ip address 10.10.10.1 255.255.255.0
ip access-group 2 in
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 2 remark CCP_ACL Category=1
access-list 2 permit any
access-list 23 remark CCP_ACL Category=17
access-list 23 permit 10.10.10.0 0.0.0.255
access-list 100 remark CCP_ACL Category=1
access-list 100 permit tcp any any
dialer-list 1 protocol ip permit
snmp-server community public RO
no cdp run
control-plane
bridge 1 protocol ieee
bridge 1 route ip
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you
want to use.
^C
banner login ^C
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE
PUBLICLY-KNOWN CREDENTIALS
Here are the Cisco IOS commands.
no username cisco
Replace <myuser> and <mypassword> with the username and password you want
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL
NOT BE ABLE TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
The reason VLAN 1 (10.10.10.x) is getting internet is because the LAN is directly connected to the router and the router has an interface belonging to that subnet (the router knows how to handle that subnet).
VLAN 2 is not configured on the router nor it has a route to reach it (the router has no clue about where VLAN 2 is supposed to be or how to handle it).
Please explain what you want to do with VLAN 2.
Federico.
Thank you, i did an ACL for the second set of IP's (192.168.1.0/24) and it works fine. The problem is that i can't lock the second "SSID Andonis".
It gives me this error message when i try to put in the key:
"key is not accepted
no more than one static keysets can be configured for dot11"
I have the Advanced Security IOS, do you think i need to get the Advanced IP Sevises IOS in order for it to work ?
V/r
Andonis
I don't think that you need to upgrade the IOS since the current IOS allows up to 10 SSIDs.
Can you post the part of the configuration for both SSIDs?
Federico.
