Problem with M1 linecard on Nexus7000
Hi all,
We have a problem with some interface on M1 linecard. When I use show module command, the output show this module is Fail as bellow:
CORE-NX7010-002# sh module
Mod  Ports  Module-Type                         Model              Status
1    48     10/100/1000 Mbps Ethernet Module    N7K-M148GT-11      ok
2    32     10 Gbps Ethernet Module             N7K-M132XP-12      ok
5    0      Supervisor module-1X                N7K-SUP1           ha-standby
6    0      Supervisor module-1X                N7K-SUP1           active *
Mod  Online Diag Status
1    Pass
2    Fail --> This is M1 linecard
5    Pass
6    Pass
When I show logging on switch, there are some output relate to this linecard:
SB-CORE-NX7010-002# sh logging
2014 May 31 03:12:33.352 SB-CORE-NX7010-002 %DIAG_PORT_LB-2-PORTLOOPBACK_TEST_FAIL: Module:2 Test:PortLoopback failed 10 cons
ecutive times. Faulty module: affected ports:10,14,16  Error:Loopback test failed. Packets lost on the SUP in the transmit direction
2014 May 31 03:12:33.360 SB-CORE-NX7010-002 %MODULE-4-MOD_WARNING: Module 2 (Serial number: JAF1303EBPK) reported warning on
ports 2/10-2/10 (Ethernet) due to Loopback test failed. Packets lost on the SUP in the transmit direction in device DEV_UNDEF
 (device error 0x41830059)
ports 2/14-2/14 (Ethernet) due to Loopback test failed. Packets lost on the SUP in the transmit direction in device DEV_UNDEF
Can someone explain for me what is problem. Any suggestion for this case ?
Trung.
15 Replies 15
Hi Sam,
I remember you reported a similar issue with one of your customers. Is this a different customer ? or the issue is happenging with the same customer ?
It sounds more and more like Cisco shipped out a bad batch of N7K-M132XP-12L cards
Thanks ! Please keep me posted !!!
Danny
