Problem with module ws-x4548-rj45v+ and 4506 switch
TjWaarsenburg
Hello I have a problem with a newly bought ws-x4548-rj45v+
i've plugged in the module but when i do show modules all , it show as unsupport
Power consumed by backplane : 0 Watts
Mod Ports Card Type                              Model              Serial No.
1     2  Supervisor IV 1000BaseX (GBIC)         WS-X4515           JAE1048GAXQ
2    48  10/100/1000BaseT (RJ45)                WS-X4448-GB-RJ45   JAB064806WN
3    48  10/100/1000BaseT (RJ45)                WS-X4448-GB-RJ45   JAB063005DB
4     0  Unsupported module                     WS-X4548-RJ45V+    JAE1545056U
M MAC addresses                    Hw  Fw           Sw               Status
1 0007.0e64.f880 to 0007.0e64.f881 5.2 12.2(20r)EW1 12.2(46)SG       Ok
2 000b.5fa4.da20 to 000b.5fa4.da4f 1.0                               Ok
3 0009.e844.d760 to 0009.e844.d78f 1.0                               Ok
4 ccef.4815.9bf0 to ccef.4815.9c1f 2.0                               Unsupport
my software version of the switch is
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-IPBASE-M), Version
12.2(46)SG, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 27-Jun-08 17:12 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x1196D96C
ROM: 12.2(20r)EW1
Dagobah Revision 226, Swamp Revision 32
SGTLH-CSW1 uptime is 7 weeks, 3 days, 21 hours, 17 minutes
System image file is "bootflash:cat4500-ipbase-mz.122-46.SG.bin"
Kind Regards,
Tom Waarsenburg
6 Replies 6
krahmani323
Level 3
Level 3
Hello Tom,
In order for the module WS-X4548-RJ45V+ to be supported in your 4500 you will need Cisco IOS Software Release 12.2(50)SG or later (you are in 12.2(46)SG).
http://www.cisco.com/en/US/prod/collateral/modules/ps2710/ps5494/product_data_sheet0900aecd802109ea_ps4324_Products_Data_Sheet.html
(WS-X4548-RJ45V+ part).
Best regards.
Karim
Arumugam Muthaiah
Hi Tom,
This is Classic Line Cards, please see the supported chassis and supervisor detail below,
Supported Chasiss:
  • Cisco Catalyst 4503, 4506, 4507R, and 4510R Switches
  • Cisco Catalyst 4503-E, 4506-E, 4507R-E, 4507R+E, 4510R-E, and 4510R+E Switch
Supported Supervisor:
  • Engine 7-E3,
  • Supervisor Engine 7L-E,
  • Supervisor Engine 6-E,
  • Supervisor Engine 6L-E3,
  • Supervisor Engine V-10GE
Note: Supervisor Engine 7-E does not support non-E-Series chassis: 4503, 4506, 4507R, and 4510R
Refer:
http://www.cisco.com/en/US/prod/collateral/modules/ps2710/ps5494/product_data_sheet0900aecd802109ea.html
Aru
*** Please rate if the post is useful ***
Regards, Aru *** Please rate if the post useful ***
I have a 4507R and Supervisor WS-X4515
In this scenario, purchase module on 48 10/100/1000 ports currently impossible?
Hello Ivan,
If you are speaking about the WS-X4548-RJ45V+ module then yes it is totally compatible as per the below link :
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/product_bulletin_c25-530557.html
The line card is compatible with all Cisco  Catalyst 4500 Series chassis, and you can deploy it with any supervisor  engine, helping ensure maximum investment protection.
Just be sure that the you are fine with the minimum supported IOS (12.2(50)SG) and the adequate power supplies on the chassis to support all the powered devices that you plan to use.
Best regards.
Karim
I see datasheet on line cards:
and this card is not compatible with the supervisor Engine IV
This line card will work with a SUPIV although the documentation omits the SUPIV in the supported SUPs listing.
