Problem with multiple ssid on cisco aironet 1130g
netone.cisco
Hi all,
my company cisco aironet 1130g access point had only one ssid (NetOneGuest) and worked normaly, know i configured another ssid but when i connect in second ssid (NetOneGuest2), i cant get IP on my PC!! the first ssid still working very well.
I think that even if i dont connect de AP on other devices, i shoud get IP address from AP, because i configured AP like dhcp server for two ssid.
In attachement is all configuration of AP for you check whats could be the problem.
Could you be so kindly to help me please.
Mauro
Hi Net One,
Thats right, on aironet autonomous you only can route from the Bridge-Group 1, so even if you can create another BVI interfaces associated with different Bridge-Groups they cannot route anything. Another thing that I could recommend you is, try to user another vlan as the Management vlan (for the Aironet, the management VLAN and Native VLAN are the same) you can use another vlan but you have to keep thata VLAN attached to the Bridge-Group 1.
For example:
interface Dot11Radio0.100
encapsulation dot1Q 100 native
no ip route-cache
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0.100
no ip route-cache
bridge-group 1
This will help you in case you don't use the vlan 1 on the switches.
Jose
andrew.prince
Level 10
Level 10
Add
interface FastEthernet0.11
bridge-group 6
no bridge-group 6 source-learning
  bridge-group 6 spanning-disabled
test again.
HTH>
netone.cisco
Hi all,
We opened a case with Cisco support, and they recomend that we should not use two interface bvi with ip addresses. and only one  bvi interface should have IP (BVI1). We should not use the same Access Point to work like DHCP server for the second pool (2º SSID "NetOneGuest2"). We configure in another server.
Now I can receive IP on my PC from 2º SSID and is working properly .
Hi Net One,
For example:
no ip route-cache
bridge-group 1
no ip route-cache
bridge-group 1
Jose
